Solved Vitelity w/ 3CX not receiving calls
Discussion in '3CX Phone System - General' started by Duggan Corp, Sep 8, 2017.
  1. Duggan Corp
    Aug 3, 2017
    6
    installed 3CX on-site, purchased a trunk from Vitelity but can't receive calls. i've seen the other threads here about similar issue. i am not on location so i cannot test outbound at this moment but can tomorrow. i believe the debian firewall is blocking the port(s) but i am unsure. i also have a hardware firewall but have the server 192.168.2.3 on DMZ. 3CX automatically opened the ports during install as i see them with a quick iptables -L command. please see 3CX activity log below (i have redacted any identifying bits)
    Code:
    09/07/2017 4:52:54 PM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 127.0.0.1:5488 tid=32186a556e19547b Call-ID=ZL1CoOEvmaIZfa-tX_AcOQ..: REGISTER sip:XXXX.west.3cx.us SIP/2.0 Via: SIP/2.0/UDP 127.0.0.1:5488;branch=z9hG4bK-524287-1---32186a556e19547b;rport=5488 Max-Forwards: 70 Contact: <sip:000@127.0.0.1:5488;rinstance=c4449f8864e329c3> To: "First Name Test Last Name Test"<sip:000@XXXX.west.3cx.us> From: "First Name Test Last Name Test"<sip:000@XXXX.west.3cx.us>;tag=96e3440e Call-ID: ZL1CoOEvmaIZfa-tX_AcOQ.. CSeq: 22 REGISTER Expires: 120 Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE Proxy-Authorization: Digest username="4vzcmzc",realm="3CXPhoneSystem",nonce="414d535959b1dbd620:ee042520aa3f639d689257f08bfbfba1",uri="sip:XXXX.west.3cx.us",response="3363bc8b9e8a3280c83e5ed72606ca9b",algorithm=MD5 Supported: replaces User-Agent: 3CX Dialer for Ext.000 Content-Length: 0 ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    09/07/2017 4:52:54 PM - [Auth] Provided response (3363bc8b9e8a3280c83e5ed72606ca9b doesn't match calc. (7056afadddefebe2d9dc76aeb0d747ab)
    09/07/2017 4:49:41 PM - Call to T:Extn:000@[Dev:sip:000@127.0.0.1:5488;rinstance=c4449f8864e329c3] from L:3.1[Ivr: PlayFile] failed, cause: Cause: 404 Not Found/INVITE from 127.0.0.1:5488
    09/07/2017 4:49:41 PM - [CM503003]: Call(C:3): Call to <sip:000@XXXX.west.3cx.us:5060> has failed; Cause: 404 Not Found/INVITE from 127.0.0.1:5488
    09/07/2017 4:49:41 PM - [Flow] Target endpoint for 5555555555 can not be built!
    09/07/2017 4:24:08 PM - PBX has dropped a message with 'User-Agent: friendly-scanner' from IP 163.172.147.216 because it is on blocked UAs list
    09/07/2017 4:19:56 PM - There's another STUN server that resolves to the same IP: 158.69.11.6:3478; ignored
    09/06/2017 4:19:55 PM - Load license has failed, error: 5
    09/06/2017 4:19:47 PM - Set log verbosity to MaxLevel = 2, Severity mask = 7
    09/06/2017 4:19:47 PM - Loading Contact records from database
    09/06/2017 4:19:29 PM - Currently active calls [none]
    09/06/2017 4:19:27 PM - Supported Mime Type added:MESSAGE(x-chat/control)
    09/06/2017 4:19:27 PM - User-Agent's that is configured to ignore: friendly-scanner,sipsak,smap,Elite 1.0 Brcm Callctrl,sipcli,VaxSIPUserAgent,VaxIPUserAgent,PortSIP,friendly-request,sip-scan,sipvicious,sundayddr,iWar,SIVuS,Gulp,sipv,siparmyknife,Test Agent,eyeBeam release 3006o stamp 17551,SIP Call,PortSIP VoIP,Conaito
    09/06/2017 4:19:27 PM - There's no valid Domain certificate/key for server's IP 192.168.2.3
    09/06/2017 4:19:27 PM - Adding secure SIP transport at 192.168.2.3:5061
    09/06/2017 4:19:27 PM - Transport 0.0.0.0:5060 is joined to SIP multicast group (interface IP: 192.168.2.3)
    09/06/2017 4:19:27 PM - Folder for SSL certificates : /var/lib/3cxpbx/Instance1/Bin/Cert
    09/06/2017 4:19:27 PM - ** Initializing SIP stack **
    09/06/2017 4:19:27 PM - [CM501006]: Default Local IP address: [192.168.2.3]
    09/06/2017 4:19:27 PM - Configuration-specified SIP IP () differs from default local IP reported by system (192.168.2.3)
    09/06/2017 4:19:27 PM - [CM501002]: Version: 15.5.0.3849
    09/06/2017 4:19:27 PM - [CM501001]: Start 3CX PhoneSystem Call Manager
    09/06/2017 4:19:27 PM - [CM501007]: *** Started Calls Controller thread ***
    09/06/2017 4:19:27 PM - Startup completed for leo:5485/DBProvider
    09/06/2017 4:19:27 PM - [EC200001]: Configuration server is connected: application:leo:5485/DBProvider local:127.0.0.1:35019 remote:127.0.0.1:5485
    09/06/2017 4:19:27 PM - Application connected:leo:5485/DBProvider
    09/06/2017 4:19:27 PM - Start management threads for leo:5485/DBProvider
    09/06/2017 4:19:27 PM - Timezone offset: -420 min.
    so i believe there's a possible license issue even though i am using freemium now, registration issue with SIP Trunk provider, and a firewall issue? any assistance is greatly appreciated!
  2. Duggan Corp
    Aug 3, 2017
    6
    Step 1: Configure the ports for your SIP Trunk / VoIP Provider
    Open the following ports to allow 3CX Phone System to communicate with the VoIP Provider/SIP Trunk & WebRTC:
    • Port 5060 (inbound, UDP) for SIP communications
    • Port 9000-9500 (inbound, UDP) for RTP (Audio) communications, which contain the actual call. Each call requires 2 RTP ports, one to control the call and one for the call data. Therefore, you must open twice as many ports if you wish to support simultaneous calls.
    let me go ahead and try step 1 first....
  3. leejor
    10,366
    228
    Was there a valid extension where 000 is? Apparently ...it can't be found. Have you tried a really simple inbound rule to a single extension?
  4. Duggan Corp
    Aug 3, 2017
    6
    there is a valid extension at 000 and i believe inbound rules are set accurately. furthermore, i ran the firewall test and passed everything. i have tested both outbound and inbound, neither of which work.
    i have some screenshots to share along with some interesting logs. please see below
    Code:
    09/08/2017 1:44:01 PM - [Flow] Target endpoint for XXXXXXXXXX can not be built!
    09/08/2017 1:41:36 PM - [Flow] Target endpoint for XXXXXXXXXX can not be built!
    09/08/2017 9:25:29 AM - Set log verbosity to MaxLevel = 2, Severity mask = 7
    09/08/2017 9:25:29 AM - Loading Contact records from database
    09/08/2017 9:25:29 AM - Failed to add outbound CID reformating rule for DN:10000: <Rules />
    09/08/2017 9:25:29 AM - Line 10000 has been updated from DB
    09/08/2017 9:25:29 AM - Dev(1414411623):[sip:XXXXXXXXXXXXt:5060 / XXXXXXX]: PBX contact is set to STUN resolved public IP: <sip:XXXXXXXXXX:5060>
    09/08/2017 9:25:29 AM - Found transport 0.0.0.0:5060/UDP
    09/08/2017 9:25:29 AM - Looking for transport to destination <sip:@XXXXXXXX:5060>
    09/08/2017 9:25:29 AM - License loaded sucessfully. License level: 1
    09/08/2017 9:25:29 AM - Supported Mime Type added:MESSAGE(x-chat/control)
    09/08/2017 9:25:29 AM - User-Agent's that is configured to ignore: friendly-scanner,sipsak,smap,Elite 1.0 Brcm Callctrl,sipcli,VaxSIPUserAgent,VaxIPUserAgent,PortSIP,friendly-request,sip-scan,sipvicious,sundayddr,iWar,SIVuS,Gulp,sipv,siparmyknife,Test Agent,eyeBeam release 3006o stamp 17551,SIP Call,PortSIP VoIP,Conaito,Ozeki,Gbomba,MizuPhone,VoIP v11.2.4,VoIP SIP v11.0.0,VoIP v11.1.2
    09/08/2017 9:25:29 AM - There's no valid Domain certificate/key for server's IP 192.168.2.3
    09/08/2017 9:25:29 AM - Adding secure SIP transport at 192.168.2.3:5061
    09/08/2017 9:25:29 AM - Transport 0.0.0.0:5060 is joined to SIP multicast group (interface IP: 192.168.2.3)
    09/08/2017 9:25:29 AM - Folder for SSL certificates : /var/lib/3cxpbx/Instance1/Bin/Cert
    09/08/2017 9:25:29 AM - ** Initializing SIP stack **
    09/08/2017 9:25:29 AM - [CM501006]: Default Local IP address: [192.168.2.3]
    09/08/2017 9:25:29 AM - Configuration-specified SIP IP () differs from default local IP reported by system (192.168.2.3)
    09/08/2017 9:25:29 AM - [CM501002]: Version: 15.5.0.3849
    09/08/2017 9:25:29 AM - [CM501001]: Start 3CX PhoneSystem Call Manager
    09/08/2017 9:25:29 AM - [CM501007]: *** Started Calls Controller thread ***
    09/08/2017 9:25:29 AM - Startup completed for leo:5485/DBProvider
    09/08/2017 9:25:29 AM - [EC200001]: Configuration server is connected: application:leo:5485/DBProvider local:127.0.0.1:41677 remote:127.0.0.1:5485
    09/08/2017 9:25:29 AM - Application connected:leo:5485/DBProvider
    09/08/2017 9:25:29 AM - Start management threads for leo:5485/DBProvider
    09/08/2017 9:25:29 AM - Timezone offset: -420 min.
    [​IMG]
  5. leejor
    10,366
    228
    What about a log of a failed outbound call. Is it being sent to the provider then rejected or does it even make it that far? Did this issue just start, or has it ever worked?
  6. Duggan Corp
    Aug 3, 2017
    6
    that's a good question and i posed it to Vitelity, which explained it wasn't reaching them. at that time, support over there told me to change the outbound ip to same inbound ip address within 3CX and viola! OK, so 3CX can receive calls and make them, however there is no audio. my ports for 9000-9050 are opened up. ideas?
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,404
    282
    Do you have one way audio or is there no audio both ways?
  8. leejor
    10,366
    228
  9. Duggan Corp
    Aug 3, 2017
    6
    not a typo, i only opened 9000-9050. thought that was enough. i just purchased a standard license key and as i understand it, i have to reinstall the system now? i will be doing that and giving this another go from the 3CX debian ISO instead of previously used debian 8.8 ISO with 3CX installed post OS.
  10. Duggan Corp
    Aug 3, 2017
    6
    close this out. houston, we have lift off.
    for those who want to know how i fixed everything: i reinstalled because i had bought the standard key. in doing so, i opted for the debain with 3CX presinstalled. all ports are already configured, which i think did the trick vs me trying to figure my way through iptables. everything is operational!! thank you leejor for you added assistance along the way!
  11. YiannisH_3CX
    May 10, 2016
    4,404
    282
    Glad to hear the issue is now resolved and thank you for sharing your solution
