Vmail attachment not displaying relevant called ID info
Discussion in '3CX Phone System - General' started by dlaborde002, Feb 26, 2018.
  1. dlaborde002
    Feb 9, 2018
    8
    Our receptionists just got new Yealink T46S IPphones and they have worked phenomenally. The only issue we are having is that whenever someone leaves a voicemail, the VMail attachment does not display any information regarding the Caller ID of the caller. Instead, it shows the information of the receptionist that transferred the call to voicemail. We have an expansion module for each receptionist, and we have a key for each employee that will transfer to his/her voicemail. The Voicemail keys are configured as followed.
    Code:
    expansion_module.1.key.10.label = Jon Doe VM
    expansion_module.1.key.10.line = 1
    expansion_module.1.key.10.type = 12
    expansion_module.1.key.10.value = *98123
    They key works great for transferring purposes, but we would like for the relevant caller information to send in the vmail attachment. I have tried using the key types: Voicemail, BLF, Speed Dial, Direct pickup, Forward. All have given me the same result. Any suggestions?
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @dlaborde002
    Just to make sure that i got this right. From your example above, a call comes in and answered by 8123, then he/she presses the BLF that sends to *98123. Is this the call flow?
    Also, i'm assuming that *9 is the dial code to connect to the voicemail of an extension?
    Can you please clarify what is shown in the From and To fields in the email received? Is it the same or there's not a from field?
  3. dlaborde002
    Feb 9, 2018
    8
    A call comes in, Extension 221(Our receptionist) answers the call. Then hits the transfer key (which places the caller on hold), and presses the BLF key that has the value of *98123. This sends the caller straight to the extensions voicemail.
    The *98 is our dial code used for "Connect to voicemail of extension".
    I will attach a snip shot of our config UI if that helps clarify. You will see that we have a BLF key, along with a Transfer to Voicemail key for each employee. expansion mod.PNG
    The Subject, and To and From lines look like this:
    Subject: New Voicemail from 221 - Receptionist
    You have received a new voice mail from "221 -"Receptionist"
    To: 243" - "John" "Doe"
    Received:"2018-02-26 09:28:16"
    Duration:"00:00:25"
    File:"vmail_221_243_20180226152816"
    #3 dlaborde002, Feb 27, 2018
  4. mariosM_3CX
    Nov 1, 2017
    406
    38
    Hi @dlaborde002
    So one can transfer the call to the voicemail of any of the configured extensions(receptionists), right? And this happens regardless of the extension's voicemail that they are transferring the call to?
    I have tested this and i cannot replicate the issue and the email i get shows the following:
    In your case, when the issue occurs, what is indicated in the From and To fields in the email that the receptionist receive?
  5. dlaborde002
    Feb 9, 2018
    8
    @mariosM_3CX
    Yes the keys are set to directly call the voicemail of the configured extension. To clarify, the "receptionist" is the employee that answers the initial call. Then, if she knows the caller's desired employee is unavailable, she presses transfer, and then presses the configured key to the employees Voicemail. The key is doing exactly what we want it to do, but the From and To fields do not display information about the initial caller. Instead it shows the information of our receptionist(the internal employee that answered the outside call). It shows:
    Duration:"00:00:25"
  6. mariosM_3CX
    Nov 1, 2017
    406
    38
    Hello @dlaborde002
    Are your BLF's configured to do an attended transfer? If yes, then this is the reason. You must do a blind transfer so the call is routed directly to the voicemail. Attended transfer means that the receptionist will first connect to the voicemail and then transfer the caller.
  7. dlaborde002
    Feb 9, 2018
    8
    @mariosM_3CX
    Yes, it is configured to do a Blink Transfer when using Transfer Mode via Dsskey. The other options are "New Call" and "Attended Transfer".
  8. dlaborde002
    Feb 9, 2018
    8
  9. mariosM_3CX
    Nov 1, 2017
    406
    38
    Hi @dlaborde002
    I'm afraid i cannot replicate this when doing a blind transfer. Caller ID of the original caller is showing in the email received. What version is your PBX?
    Also, can you try blind transferring the call to the extension's voicemail using the dial code instead of using the BLF? When you answer the call, click on transfer, dial *98123 and Blind transfer. See if this works, just to eliminate any possibility that the expansion module's BLFs are causing this.
  10. mariosM_3CX
    Nov 1, 2017
    406
    38
    Also, please post a screenshot of the email template for the new missed call that is found in Management Console >> Settings >> Email >> Email Templates Tab >> New missed call template(from drop down)
