vmail not sending emails...
Discussion in '3CX Phone System - General' started by dapatter, Feb 17, 2010.
  1. dapatter
    Feb 17, 2010
    53
    hi i am running the free version, does it support conversion and sending of vmails to emails? my vmails are sitting in the mbox, but not been sent. dont see anything in the log.
    10,587
    253
    I know that the MWI isn't enabled on the free version (4 call limit) but the comparison chart doesn't mention the email feature itself. It probably isn't included.
    You could try using the Demo Code that you would have been emailed when you registered and downloaded 3CX, it limits you to two concurrent calls but allows all of the features for testing.
  3. dweidler
    Feb 26, 2010
    5
    i had this same issue. Was originally using localhost because my smtp server was local. I changed this to the actual IP as well as changed my reply-to address to my address and it started working. Not sure which one fixed it.
