VMDIALOUTENABLED = 0 not disabling outgoing calls
Discussion in '3CX Phone System - General' started by vsefcik, Jun 14, 2010.
  1. vsefcik
    Nov 18, 2009
    19
    I read the new blog about securing 3CX at http://www.3cx.com/blog/voip-howto/securing-hints/ and checked if remote calling via voice mail was actually blocking calls. I am running version 8.0.10116 and I verified that the setting: Settings/Advanced/Custom Parameters/VMDIALOUTENABLED is set to 0 (zero), the default value. But, 3CX still allows an external caller get to voice mail (by dialing an extension that is configured to forward all calls to the voice mail SpecialMenu number), enter '9' to be sent to the options menu, enter '3' to make an outbound call, and then enter a long distance number. The call was completed and not blocked. Is there something else that needs to be changed to block external calls from the voice mail options menu?
  2. sunstate
    sunstate Member
    Dec 16, 2009
    257
    Not that this really helps you, but on a fresh install of the latest build it is disabled by default and works properly. I get "Call blocked by administrator".
  3. roth
    May 10, 2010
    13
    I'm also running 8.0.10116 and there is no custom parameter for this. I added one but it didn't disable the feture.
    Does anyone know at what version number was this implemented?
  4. sunstate
    sunstate Member
    Dec 16, 2009
    257
    I'm running 8.0.10824.716.
  5. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,500
    98
    If the feature is not implemented in your build, you cannot just simply Add the parameter and hope it works.
    Unfortunately i don't remember in which exact build this was implemented, but what you can do is just head over to the Downloads section and download the latest V8 PBX.
    If VMDIALOUTENABLED does not work for you, simply try to upgrade your Version of the PBX and see what happens.
