Voice Application Designer
Discussion in 'CRM / Helpdesk / App Integration' started by Yama, May 23, 2014.
  1. Yama
    May 23, 2014
    Hallo I buy 3CX and VAD.
    I want to build an VAD workflow.
    If i integret the workflow as "Degital Rezeptionist" the voice coming :
    "This call could not be complieded, please try again later, we apologiz."
    Of this course i made a very simple workflow that has only a "transferComponent" . But it doen´t work again.
    I make a VAD than i go to "BUILD ALL" than " Deploy" (release) and than i call in 3cx the "ActivationExtension NUMBER".
    What i make wrong ?
    I hope somebody can help me. Thanks.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi I will move this to the VAD forum.
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi there,
    Take a look at the following troubleshooting article:
    http://www.3cx.com/blog/docs/troubleshooting-vad-applications/
    Follow the steps described and let me know if you find anything wrong.
    Kind regards.
