Voice comes in but no voice goes out?
Discussion in '3CX Phone System - General' started by nmadiratta, Nov 27, 2007.
  1. nmadiratta
    Nov 27, 2007
    Just wondering if anyone has any suggestions. I'm using 3CX v 3.1 I believe, it is the latest build on the web-site. I am connecting to webcall.ca for my VOIP Provider and everything seems to authenticate okay.
    I can make/receive calls, and I can hear the other person but they cannot hear me. I'm using the 3CX Software Phone, latest version on the web-site. Just wondering if anyone has any ideas?
    I have tested the headset and verified that it works, I can even see the level indicators go up so I know the headset is working. Any ideas? Am I doing something wrong?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    make sure STUN is resolving your IP Address(you can see if theres any error message on server logs). Stun is number 1 cause of audio problems with Voip
    Cheers
  3. nmadiratta
    Nov 27, 2007
    Ahh okay. I will check in to that when I get home. Is there an STUN I could use?
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    The default 3cx uses should be enough, in some cases thoug(i had this problem) i had to go to Voip line configurations and below proxy and registrar i had to input a diferent STUN server to be used... try some of this list http://www.voip-info.org/wiki-STUN
    Cheers
  5. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good evening
    Good evening,
    When you call internally from one internal extension to another can you hear voices both directions?
    Is the extension you are calling from internal or external?
    Have you bound the extension to the media server?
    My thinking is that if you can send and recieve voice when you call another internal extension, there may be a firewall issue such as a port that needs to be opened.
    Take care
  6. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
  7. nmadiratta
    Nov 27, 2007
    Alright, I appreciate the help guys. I checked my router and had everything except for port 3478, and 9000-9003. I checked the STUN as well and that is resolving correctly in the server log.
    The problem is still there. The weird thing is that when you speak in to the mic you can hear it play back on the headset, so I'm wondering if there may be some weird issue with the 3CX software? Or if my router is sending back incoming packets to me before they can get out of the network?
    Also, I only have one ATA and one fax machine at the moment. I don't have any other extensions, although I will try setting up one after work on my laptop and see if that makes a difference.
    Any other suggestions in the mean time?
  8. Mori
    Mori New Member
    Mar 23, 2007
    223
    Port 3478 must be opened in router for STUN.
    Hope you restarts both router and 3cx after making these changes.. ;)
  9. nmadiratta
    Nov 27, 2007
    I did open it, and I restarted the router, but I may have forgotten to restart 3CX. I will try this once I get home.
  10. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good afternoon
    Can you talk to other internal extension ok then?
    You can use softphones for the other extensions if you currently only have one adapter.
