Voice flow and 3CX server
Discussion in '3CX Phone System - General' started by mleto, Mar 14, 2008.
  1. mleto
    Mar 14, 2008
    I've deployed the 3CX product and it works fine.
    When I make an IP call (I mean between two different softphones registered to the same 3CX server), all the media flow (RTP packet) go through the 3CX server even if the softphones support the same codecs.
    Is there a way to prevent this behavior ?
    Short description of my configuration:
    STUN disable
    Re-invite disable
    The softphones and the 3CX server are in the same network LAN.
    Thanks for your help
    mleto
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Enable re-invites and uncheck "PBX delivers audio" for all extensions.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Here is the description of "Voice Flow"
    http://www.3cx.com/forums/technical-manual-available-4058.html
    "The 3CX Media Server Modes"
    There is a clear description.
