Voice mail as vmail
Discussion in '3CX Phone System - General' started by beaver, Jun 23, 2009.
  1. beaver
    Aug 2, 2007
    30
    I can't get the mail server to work, everithing is set like in the previous versions but in this time the server is not sending the emails. please help.
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    5
    hmm extrange. try to reinstall system to test again.
  3. beaver
    Aug 2, 2007
    30
    what amaze me most is i can't even get a log of the mail server trying to send the emails. In fact i upgrade server yesterdey and that feature stills not working. If i saw a log of the system trying to send the email I will think that is the nat, but i don't see the server even trying.
  4. KeithB
    Jul 7, 2009
    8
    Have you got an anti-virus installed ie McAfee as there is an option on by default that will block 'mass mailings' ie emails from programs that it doesn't know about. The 3cx could be sending the emails but the anti-virus may just be stopping them reaching the SMTP server - you should be able to check the AV log, McAfee tells you the program name you have to add to the permitted list if that's the problem.
  5. ec268
    Apr 18, 2009
    22
    Please try to telnet your smtp server at 3CX machine, for making sure both servers are able to communicate.
