voice mail disactivation
Discussion in '3CX Phone System - General' started by Sergio Langa, Apr 9, 2018.
  1. Sergio Langa
    Apr 9, 2018
    We would like to disactivate the option of voicemail in order that after trying to call it does not redirect to voicemail and the call ends.
    Regards
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Hi Sergio,
    On the extension under "voicemail " you can disable the voicemail option - it is a radio button.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,099
    166
    Another option, change the forwarding rules to end the call instead of going to voicemail.
    Problem disabling voicemail, the caller will get a message saying it is not activate.
  4. eddv123
    Aug 15, 2017
    1,218
    174
    Ah yes but this should be easily solved by simply changing this message/WAV file on the 3CX server to something like empty.wav or a custom recording which would not give this away.
    The forwarding rule option cuts the call off completely.
    I guess it purely depends what behaviour suits your customer best.
