Voice Mail E-mail notification.
Discussion in '3CX Phone System - General' started by jsadan, May 25, 2010.
  1. jsadan
    May 3, 2010
    91
    I am trying to setup a email notification for Voice Mails.
    My company uses a mail service called intermedia.
    In the general tab in 3CX it gives me
    Mail Server:
    Reply Address:
    Username:
    Password:
    I have a incoming and outgoing mail server. Which one would I put as the Mail server?
    Incomming: owa.intermedia.net
    Outgoing: smtp.intermedia.net
    For a reply address I put my own email down.
  2. dab
    dab
    Nov 1, 2009
    67
    If your server does not require authentication you can just enter your outgoing mailserver(smtp.intermedia.net). If authentication is needed just fill out username and password.
  3. jsadan
    May 3, 2010
    91
    Thanks for your response. Ill definitely give that a shot. Also would I need to restart 3CX after I enter in the outgoing mail server?
