Voice mail indicator light
Discussion in '3CX Phone System - General' started by Heath, Aug 24, 2017.
  1. Heath
    Heath New Member
    Aug 12, 2017
    116
    how do you set to have the voice mail messsge indicator light flash or turn on if a messsge is waiting
    10,752
    285
    What type of device are you using? Most will work, by default, but some require the feature be enabled. Depending on the device, it will probably be a configuration file option, which, if provisioned by 3CX, should be enabled. There are also a number of options, in the extension settings, dealing with voicemail.
  3. Heath
    Heath New Member
    Aug 12, 2017
    116
  4. leejor
    10,752
    285
    Which model?
  5. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    930
    150
    It should happen automatically if you use the template but if I remember correctly you manually configured your phones. So your options are to look through the 3CX template for that option or http://lmgtfy.com/?q=aastra+mwi
  6. Heath
    Heath New Member
    Aug 12, 2017
    116
    I did it manually as it wouldn't provision automaticly.
