5qg4 said:Hi jlebeau,
Please find more information about VoiceMail System as below:
When you close the phone without press anything, it will save the message.
When you press # then you press 0 , it will save.
When/if for some reason the line stays open for 2 minutes, the voicemail will stop
recording after 2 minutes and save.
When you press # but you don't press 0 it will not save
Access VoiceMail Menu:
Dial 999 (Default Setting) a Any SIP Clients to access VoiceMail Menu
Key your Extension Number
Key your PIN, then press # or wait for timeout (need not key in #)
Press 9 for Option (Goto 2nd Level Menu)
Press # for EXIT
2nd Level Menu
Press * for Play message
Press 4 Delete All Read Message
Press 6 Play Mailbox information
Press 7 Change PIN Code
Press 8 Change the Personal Greeting
Press 9 Reply the Option
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
