Voice Mail Problem
Discussion in '3CX Phone System - General' started by richs, Jul 2, 2013.
  1. richs
    Nov 26, 2012
    9
    I am running 3CX free version 10 in Windows 7 Pro as a trial setup. I have two locations; one in Hawaii and one in Boston. I first installed in Hawaii and after the usual learning curve all works well. When I installed in Boston, however, I find the voice mail system is not coming up. 3CX management console indicates that the system extension 99 is "not registered". Dialing it from any phone brings up a busy. I have stopped and restarted all services with no result. I've rebooted the server also with no result.
    Here is a log after a system restart, attempting to call extension 99 from a desk phone:
    09:25:21.748 [CM503020]: Normal call termination. Reason: Not available
    09:25:21.748 [CM503016]: Call(2): Attempt to reach <sip:99@192.168.1.5;user=phone> failed. Reason: Not Registered
    09:25:21.748 [CM503017]: Call(2): Target is not registered: Ext.99
    09:25:21.748 [CM503010]: Making route(s) to <sip:99@192.168.1.5;user=phone>
    09:25:21.748 [CM505001]: Ext.15: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_550-UA/4.1.0.84959] PBX contact: [sip:15@192.168.1.5:5060;transport=TCP]
    09:25:21.748 [CM503001]: Call(2): Incoming call from Ext.15 to <sip:99@192.168.1.5;user=phone>
    09:25:18.347 [CM503003]: Call(1): Call to sip:10@146.115.90.2 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.6:4233
    09:25:17.926 [CM503008]: Call(1): Call is terminated
    09:25:16.475 [CM505001]: Ext.10: Device info: Device Identified: [Man: Polycom;Mod: Kirk Wireless Server;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [KIRK Wireless Server 300 PCS13__ r40447] PBX contact: [sip:10@192.168.1.5:5060;transport=TCP]
    09:25:16.475 [CM503002]: Call(1): Alerting sip:10@192.168.1.6:5060;transport=tcp
    09:25:15.914 Currently active calls - 1: [1]
    09:25:14.556 [CM503025]: Call(1): Calling Ext:Ext.10@[Dev:sip:10@192.168.1.6:5060;transport=tcp]
    09:25:14.510 [CM503004]: Call(1): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.1.6:5060;transport=tcp]
    09:25:14.494 [CM503010]: Making route(s) to <sip:10@192.168.1.5;user=phone>
    09:25:14.494 [CM505001]: Ext.15: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_550-UA/4.1.0.84959] PBX contact: [sip:15@192.168.1.5:5060;transport=TCP]
    09:25:14.494 [CM503001]: Call(1): Incoming call from Ext.15 to <sip:10@192.168.1.5;user=phone>
    09:24:15.120 [CM504001]: Ext.15: new contact is registered. Contact(s): [sip:15@192.168.1.15:5060;transport=tcp/15]
    09:21:59.626 [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:11@192.168.1.6:5060;transport=tcp/11]
    09:21:55.632 [CM504001]: Ext.10: new contact is registered. Contact(s): [sip:10@192.168.1.6:5060;transport=tcp/10]
    09:21:55.106 [CM504001]: Ext.12: new contact is registered. Contact(s): [sip:12@192.168.1.6:5060;transport=tcp/12]
    09:21:22.727 [CM504004]: Registration succeeded for: 10000@Generic SIP Trunk -
    09:21:22.497 [CM504003]: Sent registration request for 10000@Generic SIP Trunk -
    09:21:22.427 IP(s) added:[192.168.1.5]
    09:21:20.847 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=bfe257d0fc902519/*1]
    09:21:20.847 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=9f22d13da883d85e/*0]
    09:21:20.847 [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*777@127.0.0.1:40000;rinstance=440d308304ded0bc/*777]
    09:21:16.436 [EC100007]: External application is connected: application:Boston_Server:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:49184
    09:21:15.063 [CM504004]: Registration succeeded for: 10000@Generic SIP Trunk -
    09:21:14.736 [CM504003]: Sent registration request for 10000@Generic SIP Trunk -
    09:21:14.392 [EC200005]: Parking Orbit server is connected: application:Boston_Server:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:49182
    09:21:13.597 [CM506005]: Public IP=146.115.90.2 is used for WAN communications through local interface with IP=192.168.1.5
    09:21:12.474 Failed to obtain short path name for [C:\ProgramData\3CX\Bin\Cert]
    09:21:12.474 [CM501006]: Default Local IP address: [192.168.1.5]
    09:21:12.474 [CM501002]: Version: 10.0.22539.0
    09:21:12.474 [CM501001]: Start 3CX PhoneSystem Call Manager
    09:21:12.474 [CM501010]: License Info: Load Failed - Error licence Licence: 27 System: 2
    09:21:12.396 [EC200001]: Configuration server is connected: application:Boston_Server:5485/DBProvider local:127.0.0.1:49180 remote:127.0.0.1:5485
    09:21:12.396 [CM501007]: *** Started Calls Controller thread ***
    Any advice?
  2. richs
    Nov 26, 2012
    9
    For ease in setup I used a restore from Hawaii to set up the new installation in Boston. For some reason this loused up VM. After trying several times to reboot and restart services, I finally bit the bullet and uninstalled 3CX and reinstalled a clean copy and set up from scratch.
    Voice mail came right up without difficulties.
    Problem Solved.
