Voice Mail problem
Discussion in '3CX Phone System - General' started by techworx, Dec 30, 2008.
  1. techworx
    Jul 22, 2008
    17
    I am using the system with all incoming calls routed to reception ext 100. the problem i am having is when people call and it is routed to voice mail, they get a message saying leave a message and press the pound key.
    a lot of people don't bother so the line stays on hook sometimes for up to 20 mins ,blocking all other incoming calls on that line.
    is it possible
    A: change the voice mail to a more simple "please leave a message after the tone" and it then hangs up with the incoming caller hangs up.
    or
    B: if above not possible have the line just hangup when the caller hangs up to stop having the line blocked.
    I am using the free version while i still evaluate the system.
    thx in advance for any help with this
  2. techworx
    Jul 22, 2008
    17
    I am using linksys SPA3102 gateways but i taught the requirement to press the pound key is built into the 3cx system not the gateways?
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    It sounds as though the 3102 is not sending the correct signals to the 3CX system letting it know that the caller has hung up.
    Have you correctly set the 3102 up as documented in the 3CX guide?
    http: //www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE
  4. amygoda
    amygoda Member
    Sep 18, 2006
    436
    in ostn line you have set values to next items in PSTN Disconnect Detection
    Detect CPC: yes
    Detect PSTN Long Silence: yes
    PSTN Long Silence Duration: 120
    PSTN Silence Threshold: high
    Detect Disconnect Tone: yes
    Disconnect Tone: "depend on your region"
  5. techworx
    Jul 22, 2008
    17
    i wonder if anyone know the local disconnect tones for thailand? i imagine its similar to US, most things are here
  6. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    You should be able to find the info you need here:
    http://www.3amsystems.com/
    Regards
    Kevin
