Voice Mail send email
Discussion in '3CX Phone System - General' started by acgotola, May 2, 2007.
  1. acgotola
    May 2, 2007
    8
    I would like to send the recording voice mail for my coworks.
    But My email server required authentication. Where I can put this configuration in 3cx?
  2. Alexander
    Nov 10, 2006
    73
    Hi Augusto !
    The current version does not support authentication when it sends notification messages to an SMTP server.
    The easiest solution is to install Microsoft's virtual SMTP server and send notifications to this server (without authorization). In the virtual SMTP server you can organize a redistribution group which will resend all gotten messages to your SMTP server (with authorization).
  3. Anonymous
    Anonymous Guest
    Alternative to Alexanders comment ask your ISP to turn of SPF
    Sender Policy Framework (SPF, http://spf.pobox.com) is a mechanism for preventing sender forgery in SMTP transaction, thus allowing domain owners control over who may send mail from their domain.
    Than you are able to send email to their mail server without any authentication.
    Sometimes when you use mail server IP address with the SMTP port like.
    {mailserverIP}:25 it might work but that is not guaranteed.
  4. acgotola
    May 2, 2007
    8
    Thanks for help!
    I wil try to do this.
  5. Anonymous
    Anonymous Guest
    No worries, if you have no joy with your provider let me know.
    I will host your web and mail if required.
  6. ksantella
    Apr 23, 2007
    23
    Henk,
    If I am running windows server 2k3 R2 can I just add the mail server role (POP3, SMTP) to the existing server instead of a virtual server instance? I believe that windows server still requires authentication.
    Kevin
  7. Anonymous
    Anonymous Guest
    No reason to add Virtual Server, you can but you do not have to.
    I installed Exchange on my 2k3 server for my mail traffic.
    Just adding the mail server role should work.
  8. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,915
    221
    Both Windows 2000 and 2003 include a full SMTP mail server. You must install the IIS SMTP mail services. This you can use as a mail server for 3cx.
    There are also lost of freeware mail servers easy to configure and install. Here is one http://www.hmailserver.com
  9. ksantella
    Apr 23, 2007
    23
    thanks. I just wanted the ability to forward these messages to my active email since this version does not include exchange integration.
