voice mail to email
Discussion in '3CX Phone System - General' started by TSDKen, Jan 28, 2009.
  1. TSDKen
    Sep 29, 2008
    33
    I am in the process of configuring my 3CX machine.
    Everything seems to be working fine, I am able to leave voice mail and retrieve them via the phone or from the user web interface, but I am not getting the emails. I have set the extension preferences to send voice mail as attachment.
    Is there a log file that I can see what is going wrong and why my emails are not being delivered?
    Thanks,
    Ken
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Re: voice mail to email not working
    Have you specified the outgoing SMTP server in Settings > General > Mailserver
    Does it need Authentication?
    What is your configuration - what version of 3CX are you running?
  3. TSDKen
    Sep 29, 2008
    33
    yes, I have added my smtp info
    yes I have added my log in and password.
    I am running the latest version 7 release.
    it might be that my ISP is blocking port 25, but that should be obvious if there is a log I can access.
    Thanks,
    Ken
  4. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Easiest way is to telnet to an external SMTP server on port 25 from the 3CX machine - you will know in about 2 seconds if it is blocked .
  5. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Logs are here:
    Program Files\3CX PhoneSystem\Data\Logs
  6. TSDKen
    Sep 29, 2008
    33
    the logs have a lot of information, but they definitely state that the email has failed.
    I checked port 25 and it does appear to be blocked. (forgot that I had to set up outlook with an alternate port #)
    to us an alternate port number, is it as simple as writing: smtp.yourmailserver.com:200 ?
    I will let you know what happens once I get the correct port number inserted.
  7. TSDKen
    Sep 29, 2008
    33
    one more note:
    I have been trying to test it, ( I added a port number, smtp.mymailserver.com:**)
    I created a new test extension and got the following error message
    "An exception occurred EditExtension Error: The SMTP host was not found."
  8. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    You can try using smtp.yourmailserver.com:200 but it may be that 3CX expects to use port 25 at the remote end - hence the "host not found error"
    Your ISP should allow you to send outbound mail via their mailservers - any reason you aren't using those?
  9. Cjay
    Cjay New Member
    Feb 24, 2007
    203
    5
    This may be a complete red-herring, but I too had a similar problem a while back. For me the answer was that if the 3cx computer name has an underscore in it (for example I had named my machine '3cx_server') then my ISP's SMTP server would reject it. Possibly there are other invalid ASCII characters as well that the SMTP server doesn't like, however renaming my computer fixed it!
    This sort of thing can really only be seen by doing a Wireshark capture, the 3cx logs didn't display enough information on the intricacies of the SMTP dialogue.
    Chris
  10. TSDKen
    Sep 29, 2008
    33
    Comcast requires that I send using port 587.
    I have written in the smtp into 3cx like this: smtp.comcast.net:587
    I am getting this error message in the 3cx log: System.Net.Mail.SmtpException: Failure sending mail. ---> System.Net.WebException: The remote name could not be resolved: 'smtp.comcast.net:587'
    I can send email using this port 587 on my 3cx machine using outlook express.
    Ideas?
    Thanks,
    Ken
  11. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    It looks as though the SMTP port is hard-coded to 25 in 3CX.
    You will probably need to install a standalone SMTP server like the free version of mailenable on the machine and have it configured to send out through the Comcast SMTP servers, then set 3CX to use the localhost:25 address to access mailenable.
    http://www.mailenable.com/standard_edition.asp
  12. TSDKen
    Sep 29, 2008
    33
    Could someone at 3cx verify that 3cx is in fact limited to SMTP Port 25?
    If so, could a selectable port number field be added to a future release?
    Thanks,
    Ken
  13. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    There is exception. It is from System.Net.Mail. It says:
    Could you please explain how did you investigate that port "25" is hardcoded?
  14. TSDKen
    Sep 29, 2008
    33
    I was just going on what the previous post mentioned. Do you recognize another problem based on the error message:
  15. SY
    3CX Support
    Jan 26, 2007
    1,825
    it is information from .NET
    Does it specify "hardcoding" of port 25?
  16. TSDKen
    Sep 29, 2008
    33
    I am unsure of what information you are looking for. I would be happy to provide you with a log file or more information.
    Just to clarify, is it possible to use an SMTP via port 587 in 3cx?
  17. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Hi Stepan
    I have a test machine that i setup 3CX on and changed the 3CX SMTP settings to point at a test SMTP server listening on port 525
    When i put the mailserver settings as <machine name>:525 it cannot find the host.
    If i make the SMTP server listen on port 25 and put <machine name> in the 3CX settings it can find the host which makes me think 3CX only tries to contact the host on port 25, and throws an error if you try to append a port number to the end of the SMTP server address/IP.
  18. TSDKen
    Sep 29, 2008
    33
    Stepan,
    The only thing I know for sure is that I have to use SMTP Port 587 and I cannot get the 3CX system to email. Any help solving this problem would be greatly appreciated.
    Thanks,
    Ken Bell
  19. SY
    3CX Support
    Jan 26, 2007
    1,825
    Ken and Discovery
    All culprits will be executed :mrgreen:
    It is the bug, thanks a lot for the information
  20. gonzo__007
    Nov 11, 2008
    44
    while waiting for a fix you can use a port forwarder and tell to 3cx to sent the mail to the 3cx machine (itself) then the port forwader configured to forward incomming packet on port 25 will forward them to ip and port you specifiy
    never tried it, but is should work...
