Voice mail users guide
Discussion in '3CX Phone System - General' started by looker44, Apr 18, 2013.
  1. looker44
    Dec 31, 2012
    37
    We have remote technologists that will be dialing in to access voice mail. Is there a 123 simple PDF for voicemail setup and guide? Also where is the 3cx welcome/notification template and is it editable?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    252
    Setup welcome email: Settings -> MailServer tab -> Customize button
    voicemail how to: http://www.3cx.com/blog/extension-user-manual/check-your-voicemail/
    It is not a PDf - but you can print it to PDF. of course, you will have to setup a DID to extension 9999. And, I do not see this mentioned, but the user must first enter extension (without a #) then it will ask for Voicemail PIN.
  3. looker44
    Dec 31, 2012
    37
    appreciate it but we have remote users dialing into the voicemail to get info. they do not have phoneset
  4. craigreilly
    Feb 1, 2012
    3,321
    252
    Right - wrong link...
    1) Setup a DID (if you have one available) and route it to your VM extension (99,999,9999,99999)
    2) If you use an automated attendant, have them dial the extension for VM when it answers
    Then when it answers enter their extension (do not hit # here)
    wait for it to ask for PIN, enter it and hit #
    And so - use this:
    http://www.3cx.com/blog/extension-user-manual/configure-your-voice-mail/
    All this information is very easy to find on 3cx pages if you do a search.
    Enjoy!
