Voice Mail when extension is not registered.
Discussion in '3CX Phone System - General' started by mbehlok, Dec 15, 2006.
  1. mbehlok
    Dec 15, 2006
    19
    Just want to say that i just started to use this software and it has been working great.
    The one thing I have a question about, which may have been brought up before. When an extension is not registered, the Voice Mail system does not pick up, and all I get is "Unallocated Number". When that extension is registered, the system works fine. Is there an easy way to have anyone not registered to go directly to Voice Mail, that way if the user is not logged in on the soft phone, that call is not missed?
    Thanks again and keep up the good work..
    Mark
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    308
    Voice mail when not registered
    Thanks for your nice feedback! :)
    Yes, we are adding this feature to the next beta. Call forward on busy/not registered or direct to voice mail. It was an oversight that it was not in this beta.
    It should be ready by second week January (the new beta)
