Voice Mail
Discussion in '3CX Phone System - General' started by julius, Sep 22, 2007.
  1. julius
    Sep 22, 2007
    11
    I just installed the free version, Does anybody know how the voice mail is set-up. I dialed 999 and I connect but I don't hear anything.
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    If you have not changed the default extension then 999 is right, you should hear a response asking for extension number and password. I presume you have the voicemail option selected on at least one extension that you created?
  3. zakfleming
    Aug 17, 2007
    48
    When you install 3CX it will ask you how many digits you want for your voicemail, it you select 4 will it still be 999 or 9999?
  4. Anonymous
    Anonymous Guest
    Why not go to the General --> General Settings and check voice mail settings.
    You will have special voice menu extension number, by default that is 999.
    You might have something else dial that number to access voice mail, keep in mind you have to configure voice mail for an extension first.
  5. julius
    Sep 22, 2007
    11
    I have 999 but when I dial that ext. it establish but i don't hear anything.
  6. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    999 isn't an actual extension or voicemail, its voicemail access. Do you have voicemail enabled on another extension?
  7. julius
    Sep 22, 2007
    11
    It works now. I install it on 2000 server on a data center, but when I install it on windows XP it work well.
  8. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    Not sure why that is. Mine runs on Windows 2000 Adv Server in two locations with no issues. Should have worked fine for you. Oh well! If it ain't broke, don't fix it! :lol:
  9. julius
    Sep 22, 2007
    11
    My 2000 server doesn't have audio. That's why it is just silent when i try to access the voicemail. I also tested it on 2003 with no audio.
  10. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    When you say no audio do you mean no sound card installed? I never really thought of that but would be very surprised that a piece of hardware that serves no useful purpose on a Server would influence 3CX audio since the VoIP extension devices are the actual sound hardware in the setup. Am I missing something? Any ideas anyone?
  11. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Im running 3CX myself on a Computer with 2k3 server with no audio card installed and i have 0 issues with it....
    Cheers
  12. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    That is exactly what I expected. I have to admit I don't remember if either of my Servers have sound cards, was unimportant so never paid attention.
  13. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    My Win 2K3 server has no sound card either. You do not need one for this application.
  14. julius
    Sep 22, 2007
    11
    I think it's my firewall settings since it's in my data center
  15. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Can you make calls? Do you hear two audio then?
  16. julius
    Sep 22, 2007
    11
    no I don't
    I have a sonic wall firewall installed and I opened all the ports
