Voice Mail
Discussion in '3CX Phone System - General' started by kmafsar, Oct 22, 2007.
  1. kmafsar
    Oct 20, 2007
    how I can listen the received voice mail, I used 3CX with X-lite and 3CX call Assistant.
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    If you havent changed it, dial 999 or 9999(if using 4 number extension) , voice mail then will ask to input your extension number and voice mail password. If this doesnt work, try to go general setting on the Web admin page and see the voice mail number there, also go to your extension settings and change your password for one of your own.
    Cheers
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    If using default setting & 3 digits for extensions:
    Dial 999 then follow the voice menu
    If using default setting & 4 digits for extensions:
    Dial 9999 then follow the voice menu
