voice mailboxes
Discussion in '3CX Phone System - General' started by KenC, Mar 31, 2012.
  1. KenC
    Mar 29, 2012
    85
    I have one sip, that is registered. I want incoming calls sorted by call attendant to six vm boxes. How do I set them up.
  2. KenC
    Mar 29, 2012
    85
    Thanks to all, in advance!
  3. leejor
    10,574
    247
    Create six extensions with mailboxes
    Create attendant, set options to direct caller to each extension. Record necessary instructions to callers as to what to select. See manual, page 47.... http: //www.3cx.com/manual/3CXPhoneSystemManual10.pdf NO LONGER AVAILABLE. NEW LINK: http://www.3cx.com/docs/manual/
    Direct incoming trunk to attendant.
  4. KenC
    Mar 29, 2012
    85
    thank you.
    the next related issue is how to set greeting for extensions, and how to link myphone client to unregistered extensions.
  5. leejor
    10,574
    247
    You would need to temporarily register an extension for each mailbox, to access the menu, allowing you record a message.
    As for Myphone...Can't help you there as I don't use it, myself. I would assume that you would have to have an extension registered to make use of it. http://www.3cx.com/blog/myphone/
