voice message when transferring to voice mail
Discussion in '3CX Phone System - General' started by mckey415, Oct 11, 2007.
  1. mckey415
    Jun 27, 2007
    24
    hi!
    i have the following question - should there be a voice message when call is transferred to the voice mailbox? when i call to extension which is not available there's only silence in my system... at the same time in logs i see the following receord:
    [MS007005] Call(76) Ext.0001: Failed to open file "C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB\record_your_message.mp3" to play on EP 00000073@x.x.x.x. 'silent' RTP stream will be sent.
    is it something wrong with my system?
    thanks in advance
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Seems like server cant find the message to play, try to change prompt language on the web admin page just to see if it works, if it does then that means you have files missing on your server for you other language.... a reinstall would solve that problem...
    Cheers
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Have you tried it as a wav file? Try recording the VM message from another phone for that extension. It should save as a wav file not an MP3.
    I haven't tried MP3 yet on 3CX but it might help troubleshoot what's going on.
  4. olicharl
    Oct 21, 2007
    I have exactly the same message on a Windows Server 2003 web edition, after installed the latest version of CX available :
    " [MS007005] Call(1) Ln:10000@VoIPCheap : Failed to open file "C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Prompts\Sets\8210986B-9412-497f-AD77-3A554F4A9BDB\record_your_message.mp3" to play on EP 00000001@. 'silent' RTP stream will be sent.
    The is the default setup. What's wrong ??
    Any help will be appreciated.
    Thx,
    Olivier Charlier,
    Belgium.
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    I never make mp3 works at current version (3.1 Build 2434). It should be wave file in PCM, 8 kHz, 16 bit, Mono format at VM default greeting, VM personal greeting, recorded voice message and prompts. The MP3 at such folder may be for test or other propose. Please correct me if I'm wrong.
  6. mckey415
    Jun 27, 2007
    24
    i made exactly as you said (create a wav file in pcm, 8 kHz, 16bit format)and it solved the problem. now i can hear a voice message when transferring to voice mail.
    thanks a lot.
  7. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Strange Thing, Mp3's work here.... :|
    Anyway, im glad you solved your problem.
    Cheers
