VoiceFlex. sometime fails to connect - 488 Not acceptable he
The version that I have is the latest available on your web site - 8.0.10824.716. We are currently using the Free licence. We will consider purchasing a licence once we are confident that this system will work reliably. I have another outstand message thread regarding the daily 3CX crashes that we are getting.
Here are the logs:
Successfull call:
3CXPhoneSystemLog
INVITE sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 193.255.1.38:5060;branch=z9hG4bK-ce92e438
Max-Forwards: 70
Contact: "Tony Kirke"<sip:
[email protected]:5060>
To: <sip:
[email protected]>
[email protected]>;tag=cef3d4184ea4d0e0o0
Call-ID:
[email protected]
CSeq: 102 INVITE
Expires: 240
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
Proxy-Authorization: Digest username="50",realm="3CXPhoneSystem",nonce="414d535c01f9ac6985:3d75c4505c7caf65e827189692f2e0ba",uri="sip:
[email protected]:5060",algorithm=MD5,response="0c81e770c6d37f30f113999c6c1685f0"
Supported: replaces
User-Agent: Cisco/SPA502G-7.4.4
Content-Length: 0
<br>
09:55:05.249|.\CallCtrl.cpp(161)|Log2||CallCtrl:
nIncomingCall:[CM503001]: Call(19): Incoming call from Ext.50 to <sip:
[email protected]><br>
09:55:05.249|.\Extension.cpp(1067)|Log3||Extension:
rintEndpointInfo:[CM505001]: Ext.50: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA502G-7.4.4] PBX contact: [sip:
[email protected]:5060]<br>
09:55:05.249|.\CallLeg.cpp(951)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:19.1<br>
09:55:05.249|.\SLServer.cpp(794)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:19.1:Offer received. RTP connection: 193.255.1.38:16464(16465)<br>
09:55:05.249|.\CallCtrl.cpp(331)|Log3||CallCtrl:
nSelectRouteReq:[CM503010]: Making route(s) to <sip:
09:55:05.249|.\CallCtrl.cpp(446)|Log2||CallCtrl:
nSelectRouteReq:[CM503004]: Call(19): Route 1: VoIPline:02085412746@(Ln.10002@VoiceFlex)@[Dev:sip:
09:55:05.343|.\SLServer.cpp(794)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:19.2:Offer provided. Connection(transcoding mode): 89.145.219.71:13422(13423)<br>
09:55:05.343|.\Target.cpp(430)|Log2||Target::makeOneInvite:[CM503025]: Call(19): Calling VoIPline:02085412746@(Ln.10002@VoiceFlex)@[Dev:sip:
3CXMedaServer.trace.log
09:55:05.249|.\MSEndPoint.cpp(760)|Trace5||??:00000046@: RTP bind address 193.255.1.27:7078
09:55:05.249|.\MSEndPoint.cpp(771)|Trace5||??:00000046@: RTCP bind address 193.255.1.27:7079
09:55:05.249|.\MediaServer.cpp(815)|Trace5||??:EndPoint created: (destination=193.255.1.38)
EndPoint: ID=00000046@(LOCAL)
LOGID=C:19.1 Status: MSEP_LOCAL
RTP:193.255.1.27:7078
RTCP:193.255.1.27:7079
STUN RTP:0.0.0.0:0
STUN RTCP:0.0.0.0:0
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Party RTCP:0.0.0.0:0
Decoders:
<empty>
09:55:05.249|.\MediaServer.cpp(1260)|Trace5||??:EP 00000046@ joined to call 19
09:55:05.249|.\MediaServer.cpp(1269)|Trace5||??:starting send on new call 19
09:55:05.249|.\MediaServer.cpp(912)|Trace5||??:Set Party EP:C:19.1SDP:v=0
o=- 59450265 59450265 IN IP4 193.255.1.38
s=-
c=IN IP4 193.255.1.38
t=0 0
m=audio 16464 RTP/AVP 0 2 8 9 18 96 97 98 101
a=rtpmap:0 PCMU/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:18 G729a/8000
a=rtpmap:96 G726-40/8000
a=rtpmap:97 G726-24/8000
a=rtpmap:98 G726-16/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
09:55:05.249|.\MSEndPoint.cpp(2949)|Trace5||??:New state00000046@ SILENCE
09:55:05.249|.\MSEndPoint.cpp(1691)|Trace5||??
artyAddrRTP_ is set to 193.255.1.38:16464
09:55:05.249|.\MSEndPoint.cpp(1692)|Trace5||??
artyAddrRTCP_ is set to 193.255.1.38:16465
09:55:05.249|.\MSEndPoint.cpp(1914)|Log2||??:[MS210000] C:19.1:Offer received. RTP connection: 193.255.1.38:16464(16465)
09:55:05.343|.\MSEndPoint.cpp(1007)|Trace5||??:Source ports: 9010 STUN RTP:89.145.219.71:13422 RTCP:89.145.219.71:13423 mapped to 89.145.219.71, ports 13422,13423
09:55:05.343|.\MediaServer.cpp(815)|Trace5||??:EndPoint created: (destination=146.101.248.200)
EndPoint: ID=00000047@(EXTERNAL)
LOGID=C:19.2 Status: MSEP_STUN
STUN RTCP:89.145.219.71:13423
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Decoders:
<empty>
09:55:05.343|.\MediaServer.cpp(1260)|Trace5||??:EP 00000047@ joined to call 19
09:55:05.343|.\MediaServer.cpp(1305)|Trace5||??:EndPoint 00000047@ removed from call 19
09:55:05.343|.\MSEndPoint.cpp(1403)|Log2||??:[MS210002] C:19.2:Offer provided. Connection(transcoding mode): 89.145.219.71:13422(13423)
09:55:05.343|.\MediaServer.cpp(850)|Trace5||??:Get Local SDP. EP:C:19.2SDP:v=0
o=3cxPS 473872465920 108213043201 IN IP4 89.145.219.71
s=3cxPS Audio call
c=IN IP4 89.145.219.71
t=0 0
m=audio 13422 RTP/AVP 0 8 101
a=sendrecv
09:55:06.232|.\MSEndPoint.cpp(1007)|Trace5||??:Source ports: 9012 STUN RTP:89.145.219.71:13424 RTCP:89.145.219.71:13425 mapped to 89.145.219.71, ports 13424,13425
09:55:06.232|.\MediaServer.cpp(815)|Trace5||??:EndPoint created: (destination=146.101.248.200)
EndPoint: ID=00000048@(EXTERNAL)
LOGID=C:20.1 Status: MSEP_STUN
STUN RTCP:89.145.219.71:13425
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Decoders:
<empty>
09:55:06.232|.\MediaServer.cpp(1260)|Trace5||??:EP 00000048@ joined to call 20
09:55:06.232|.\MediaServer.cpp(1269)|Trace5||??:starting send on new call 20
09:55:06.232|.\MediaServer.cpp(912)|Trace5||??:Set Party EP:C:20.1SDP:v=0
o=root 14580 14580 IN IP4 146.101.248.200
s=session
c=IN IP4 146.101.248.200
t=0 0
m=audio 28052 RTP/AVP 0 8 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=silenceSupp
ff - - - -
a=ptime:20
a=sendrecv
09:55:06.232|.\MSEndPoint.cpp(2949)|Trace5||??:New state00000048@ SILENCE
09:55:06.232|.\MSEndPoint.cpp(1691)|Trace5||??
artyAddrRTP_ is set to 146.101.248.200:28052
09:55:06.232|.\MSEndPoint.cpp(1692)|Trace5||??
artyAddrRTCP_ is set to 146.101.248.200:28053
09:55:06.232|.\MSEndPoint.cpp(1914)|Log2||??:[MS210000] C:20.1:Offer received. RTP connection: 146.101.248.200:28052(28053)
09:55:06.263|.\MSEndPoint.cpp(760)|Trace5||??:00000049@: RTP bind address 193.255.1.27:7080
09:55:06.263|.\MSEndPoint.cpp(771)|Trace5||??:00000049@: RTCP bind address 193.255.1.27:7081
09:55:06.263|.\MediaServer.cpp(815)|Trace5||??:EndPoint created: (destination=193.255.1.39)
EndPoint: ID=00000049@(LOCAL)
LOGID=C:20.2 Status: MSEP_LOCAL
RTP:193.255.1.27:7080
RTCP:193.255.1.27:7081
STUN RTP:0.0.0.0:0
STUN RTCP:0.0.0.0:0
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Decoders:
<empty>
09:55:06.263|.\MediaServer.cpp(1260)|Trace5||??:EP 00000049@ joined to call 20
09:55:06.263|.\MediaServer.cpp(1305)|Trace5||??:EndPoint 00000049@ removed from call 20
09:55:06.263|.\MSEndPoint.cpp(1403)|Log2||??:[MS210002] C:20.2:Offer provided. Connection(transcoding mode): 193.255.1.27:7080(7081)
09:55:06.263|.\MediaServer.cpp(850)|Trace5||??:Get Local SDP. EP:C:20.2SDP:v=0
o=3cxPS 526083162112 19931332609 IN IP4 193.255.1.27
s=3cxPS Audio call
c=IN IP4 193.255.1.27
t=0 0
m=audio 7080 RTP/AVP 0 8 3 13 110 99 101
a=rtpmap:3 GSM/8000
a=rtpmap:13 CN/8000
a=rtpmap:110 iLBC/8000
a=rtpmap:99 SPEEX/8000
a=sendrecv
09:55:07.137|.\MediaServer.cpp(1305)|Trace5||??:EndPoint 00000046@ removed from call 19
09:55:07.137|.\MediaServer.cpp(1065)|Trace5||??:references to EndPoint 00000046@ were removed
09:55:07.262|.\MediaServer.cpp(1065)|Trace5||??:references to EndPoint 00000047@ were removed
09:55:07.262|.\MediaServer.cpp(1383)|Trace5||??:references to call 19 were removed
09:55:07.278|.\MSCallConf.cpp(36)|Trace5||??:Call: 19 destroyed
09:55:07.294|.\MSEndPoint.cpp(847)|Trace5||??:EndPoint 00000047@ destroyed
09:55:07.294|.\MSEndPoint.cpp(848)|Trace5||??:EndPoint 00000047@ destroyed statistics:
Begin send:0
LastSent:0
TotalSent:0
MaxSendInterval:0
MinSendInterval:0
AvgSendInterval:0
SendDeviation:0
Begin recv:0
Last recv:0
TotalRecv:0
MaxRecvInterval:0
MinRecvInterval:0
AvgRecvInterval:0
ReceiveDeviation:0
09:55:07.481|.\MediaServer.cpp(1305)|Trace5||??:EndPoint 00000048@ removed from call 20
09:55:07.481|.\MediaServer.cpp(1065)|Trace5||??:references to EndPoint 00000049@ were removed
09:55:07.481|.\MediaServer.cpp(1065)|Trace5||??:references to EndPoint 00000048@ were removed
09:55:07.481|.\MediaServer.cpp(1383)|Trace5||??:references to call 20 were removed
09:55:07.496|.\MSCallConf.cpp(36)|Trace5||??:Call: 20 destroyed
09:55:07.793|.\MSEndPoint.cpp(847)|Trace5||??:EndPoint 00000048@ destroyed
09:55:07.793|.\MSEndPoint.cpp(848)|Trace5||??:EndPoint 00000048@ destroyed statistics:
Begin send:0
LastSent:0
TotalSent:0
MaxSendInterval:0
MinSendInterval:0
AvgSendInterval:0
SendDeviation:0
Begin recv:0
Last recv:0
TotalRecv:0
MaxRecvInterval:0
MinRecvInterval:0
AvgRecvInterval:0
ReceiveDeviation:0
09:55:07.965|.\MSEndPoint.cpp(847)|Trace5||??:EndPoint 00000049@ destroyed
09:55:07.965|.\MSEndPoint.cpp(848)|Trace5||??:EndPoint 00000049@ destroyed statistics:
Begin send:0
LastSent:0
TotalSent:0
MaxSendInterval:0
MinSendInterval:0
AvgSendInterval:0
SendDeviation:0
Begin recv:0
Last recv:0
TotalRecv:0
MaxRecvInterval:0
MinRecvInterval:0
AvgRecvInterval:0
ReceiveDeviation:0
09:55:08.433|.\MSEndPoint.cpp(847)|Trace5||??:EndPoint 00000046@ destroyed
09:55:08.433|.\MSEndPoint.cpp(848)|Trace5||??:EndPoint 00000046@ destroyed statistics:
Begin send:0
LastSent:0
TotalSent:0
MaxSendInterval:0
MinSendInterval:0
AvgSendInterval:0
SendDeviation:0
Begin recv:0
Last recv:0
TotalRecv:0
MaxRecvInterval:0
MinRecvInterval:0
AvgRecvInterval:0
ReceiveDeviation:0
Failed Call
3CXPhoneSystemLog
08:39:18.711|.\CallLeg.cpp(123)|Log5||CallLeg:
nNewCall:[CM500002]: Info on incoming INVITE:
INVITE sip:
Via: SIP/2.0/UDP 193.255.1.38:5060;branch=z9hG4bK-ca07f9fe
Max-Forwards: 70
To: <sip:
[email protected]>
[email protected]>;tag=ae58853e86117239o0
Call-ID:
[email protected]
CSeq: 102 INVITE
Expires: 240
Proxy-Authorization: Digest username="50",realm="3CXPhoneSystem",nonce="414d535c01f99aa605:37127981c1a81f1547c610f9ac369a85",uri="sip:
[email protected]:5060",algorithm=MD5,response="893b482b52dff1e27f05450e16ea22d4"
Supported: replaces
Content-Length: 0
<br>
08:39:18.727|.\CallCtrl.cpp(161)|Log2||CallCtrl:
nIncomingCall:[CM503001]: Call(3): Incoming call from Ext.50 to <sip:
08:39:18.727|.\Extension.cpp(1067)|Log3||Extension:
08:39:18.727|.\CallLeg.cpp(951)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:3.1<br>
08:39:18.727|.\SLServer.cpp(794)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:3.1:Offer received. RTP connection: 193.255.1.38:16454(16455)<br>
08:39:18.727|.\CallCtrl.cpp(331)|Log3||CallCtrl:
08:39:18.727|.\CallCtrl.cpp(446)|Log2||CallCtrl:
nSelectRouteReq:[CM503004]: Call(3): Route 1: VoIPline:02085412746@(Ln.10002@VoiceFlex)@[Dev:sip:
08:39:18.805|.\SLServer.cpp(794)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:3.2:Offer provided. Connection(transcoding mode): 89.145.219.71:13364(13365)<br>
08:39:18.805|.\Target.cpp(430)|Log2||Target::makeOneInvite:[CM503025]: Call(3): Calling VoIPline:02085412746@(Ln.10002@VoiceFlex)@[Dev:sip:
08:39:18.883|.\CallLeg.cpp(268)|Log2||CallLeg:
nFailure:[CM503003]: Call(3): Call to sip:
[email protected]:5060 has failed; Cause: 488 Not acceptable here; from IP:146.101.248.200:5060<br>
08:39:18.883|.\Call.cpp(774)|Log2||Call::RouteFailed:[CM503016]: Call(3): Attempt to reach <sip:
[email protected]> failed. Reason: Not Implemented<br>
08:39:18.883|.\Call.cpp(433)|Log2||Call:
oEndCall:[CM503020]: Normal call termination. Reason: Server Failure<br>
08:39:18.711|.\MSEndPoint.cpp(760)|Trace5||??:00000025@: RTP bind address 193.255.1.27:7042
08:39:18.711|.\MSEndPoint.cpp(771)|Trace5||??:00000025@: RTCP bind address 193.255.1.27:7043
08:39:18.711|.\MediaServer.cpp(815)|Trace5||??:EndPoint created: (destination=193.255.1.38)
EndPoint: ID=00000025@(LOCAL)
LOGID=C:3.1 Status: MSEP_LOCAL
RTP:193.255.1.27:7042
RTCP:193.255.1.27:7043
STUN RTP:0.0.0.0:0
STUN RTCP:0.0.0.0:0
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Decoders:
<empty>
08:39:18.727|.\MediaServer.cpp(1260)|Trace5||??:EP 00000025@ joined to call 3
08:39:18.727|.\MediaServer.cpp(1269)|Trace5||??:starting send on new call 3
08:39:18.727|.\MediaServer.cpp(912)|Trace5||??:Set Party EP:C:3.1SDP:v=0
o=- 58995680 58995680 IN IP4 193.255.1.38
s=-
t=0 0
m=audio 16454 RTP/AVP 0 2 8 9 18 96 97 98 101
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
08:39:18.727|.\MSEndPoint.cpp(2949)|Trace5||??:New state00000025@ SILENCE
08:39:18.727|.\MSEndPoint.cpp(1691)|Trace5||??
artyAddrRTP_ is set to 193.255.1.38:16454
08:39:18.727|.\MSEndPoint.cpp(1692)|Trace5||??
artyAddrRTCP_ is set to 193.255.1.38:16455
08:39:18.727|.\MSEndPoint.cpp(1914)|Log2||??:[MS210000] C:3.1:Offer received. RTP connection: 193.255.1.38:16454(16455)
08:39:18.805|.\MSEndPoint.cpp(1007)|Trace5||??:Source ports: 9030 STUN RTP:89.145.219.71:13364 RTCP:89.145.219.71:13365 mapped to 89.145.219.71, ports 13364,13365
08:39:18.805|.\MediaServer.cpp(815)|Trace5||??:EndPoint created: (destination=146.101.248.200)
EndPoint: ID=00000026@(EXTERNAL)
LOGID=C:3.2 Status: MSEP_STUN
STUN RTCP:89.145.219.71:13365
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Decoders:
<empty>
08:39:18.805|.\MediaServer.cpp(1260)|Trace5||??:EP 00000026@ joined to call 3
08:39:18.805|.\MediaServer.cpp(1305)|Trace5||??:EndPoint 00000026@ removed from call 3
08:39:18.805|.\MSEndPoint.cpp(1403)|Log2||??:[MS210002] C:3.2:Offer provided. Connection(transcoding mode): 89.145.219.71:13364(13365)
08:39:18.805|.\MediaServer.cpp(850)|Trace5||??:Get Local SDP. EP:C:3.2SDP:v=0
o=3cxPS 404700004352 334839676929 IN IP4 89.145.219.71
s=3cxPS Audio call
t=0 0
m=audio 13364 RTP/AVP 0 8 101
a=sendrecv
08:39:18.883|.\MediaServer.cpp(1065)|Trace5||??:references to EndPoint 00000026@ were removed
08:39:18.945|.\MediaServer.cpp(1305)|Trace5||??:EndPoint 00000025@ removed from call 3
08:39:18.945|.\MediaServer.cpp(1065)|Trace5||??:references to EndPoint 00000025@ were removed
08:39:18.945|.\MediaServer.cpp(1383)|Trace5||??:references to call 3 were removed
08:39:18.945|.\MSCallConf.cpp(36)|Trace5||??:Call: 3 destroyed
08:39:20.412|.\MSEndPoint.cpp(847)|Trace5||??:EndPoint 00000026@ destroyed
08:39:20.412|.\MSEndPoint.cpp(848)|Trace5||??:EndPoint 00000026@ destroyed statistics:
Begin send:0
LastSent:0
TotalSent:0
MaxSendInterval:0
MinSendInterval:0
AvgSendInterval:0
SendDeviation:0
Begin recv:0
Last recv:0
TotalRecv:0
MaxRecvInterval:0
MinRecvInterval:0
AvgRecvInterval:0
ReceiveDeviation:0
08:39:20.475|.\MSEndPoint.cpp(847)|Trace5||??:EndPoint 00000025@ destroyed
08:39:20.475|.\MSEndPoint.cpp(848)|Trace5||??:EndPoint 00000025@ destroyed statistics:
Begin send:0
LastSent:0
TotalSent:0
MaxSendInterval:0
MinSendInterval:0
AvgSendInterval:0
SendDeviation:0
Begin recv:0
Last recv:0
TotalRecv:0
MaxRecvInterval:0
MinRecvInterval:0
AvgRecvInterval:0
ReceiveDeviation:0
