voicemail - accessing from outside?
Discussion in '3CX Phone System - General' started by h2009, Apr 12, 2008.
  1. h2009
    h2009 Member
    Mar 15, 2008
    447
    Is there any way to access the voicemail from the outside, i.e. by calling in to the PBX?
    I know there's the email function, but i was wondering about dialing into the system.
  2. Arnaud
    Nov 23, 2007
    43
    Have you tried using the digital receptionist ?
    Especially the function "Allowing callers to dial a known extension directly" described in the userguide (page 43) is probably offering what you're looking for. If you have a spare voip or DID number you can also have that forwarded to your voicemail extension immediatly.
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    Oh thats a good idea. Thanks i'll give it ago.
  4. Andy Schmidt
    Andy Schmidt New Member
    Apr 3, 2008
    118
    I think the manual says you need to dial "999" when you get to the Automated Attendant - but, in my case (2 digit extension), it appears to be "99" instead.
  5. h2009
    h2009 Member
    Mar 15, 2008
    447
    I can confirm the idea works.
    I setup a line i could dial with sipgate, then set all incoming calls to divert to 'special menu' and thats the way you can access your VM from outside.
