Voicemail And Call Log Issues
Discussion in '3CX Phone System - General' started by captainahab, Mar 16, 2011.
  1. captainahab
    Mar 16, 2011
    Hi there
    I've just installed the Free version and I'm having a few problems,
    Firstly, when a user leaves a voicemail it's not sending it to email, so I looked into the /myphone page and noticed that no voicemails are being recorded, also it doesn't seem to be logging ANY inbound/outbound or missed calls. I'm basically out of my depth and don't really know where to start looking.....
    Can anyone help me
    James.
  2. captainahab
    Mar 16, 2011
    Has anyone got an idea to point me in the right direction ?
    James.
  3. captainahab
    Mar 16, 2011
    I've just noticed it's only NOT showing the call logs in Webkit browsers, but I can see everything in Firefox, but I'm still having issues with Voicemail,
    Firstly when I try to record a voicemail greeting, after pressing # then the 0 to save the recording, it just stops and does nothing, but also I can't listen to any voicemails as I don't think its recording any.
