Voicemail and Email
Discussion in '3CX Phone System - General' started by bduke08021, Jul 31, 2009.
  1. bduke08021
    Jun 20, 2009
    34
    So here is the deal, i know my server, user, and password info is correct, i have verified it. at one point 3cx was sending voicemails, but no sound. Also when leaving the voicemail, could not hear the ivr service.
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Some more info would help like 3CX version, OS and network setup.
  3. leejor
    11,086
    325
    Are the phone and the 3CX on the same LAN?
  4. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    If you are running Server 2008 make sure that you have installed the Desktop Experience role.
  5. bduke08021
    Jun 20, 2009
    34
    I am sorry, when i say sending voicemail, i meant in an email as an attachment. i am runnig the latest 3cx. I know that my smtp info is good, and it is entered in the 3cx.
  6. tpinnovations
    Jul 30, 2009
    296
    It is extremely difficult to offer advice or professional opinion when we do not have a full picture of how your system is setup and operating.
    Please provide the following information so that we can help you.
    Operating System Information
    Mail Server Information
    Network Setup Information
  7. bduke08021
    Jun 20, 2009
    34
    OS= Vista
    Mail Server= ISP SMTP (outgoing.verizon.net)
    Network Type= Peer to Peer, with proxy and firewall, niether applies to the phone server. Which means that the server has free access to internet.
  8. tpinnovations
    Jul 30, 2009
    296
    Just to make sure;
    You have setup the outgoing mail server with both the user name and password?
    You have Windows Media Player with the normal codecs installed?
    You have two way audio on all extensions, trunks, cards, etc.
    Does music on hold work?
    You have checked that "PBX Delivers Audio" is enabled on the incoming trunk?
    Also,
    What kind of SIP devices do you have?
    Do you use an ATA or a SIP Trunk?
  9. bduke08021
    Jun 20, 2009
    34
    You have setup the outgoing mail server with both the user name and password? =====Yes
    You have Windows Media Player with the normal codecs installed? =====Not Sure
    You have two way audio on all extensions, trunks, cards, etc. =======Explian
    Does music on hold work? ======Yes, but it didn't
    You have checked that "PBX Delivers Audio" is enabled on the incoming trunk? =====Yes
    I am using both PSTN Gateway (skype), and Call Centric (VOIP)
  10. tpinnovations
    Jul 30, 2009
    296
    Go to Start > All Programs > See if Windows Media Player is there. If its not you will need to download and install it so your computer can process the audio.
    Two way audio means you can hear and talk to the person on the other end of the line from both ends. EG, Everything works just peachy.
    If your music on hold isn't working that leaves me to believe its an audio codec issue.
  11. bduke08021
    Jun 20, 2009
    34
    Voicemail works, it is not emailing the notificaton. At one point i didn't get audio but got the notification, until i played with some settings. So i have everything working but the emails.
  12. tpinnovations
    Jul 30, 2009
    296
    Can you turn on debug logging, leave a voicemail and post the log to the forum.
  13. bduke08021
    Jun 20, 2009
    34
    i know the email server works and the settings are right because i can get an email when i set up ext.
  14. bduke08021
    Jun 20, 2009
    34
    still need help here
  15. tpinnovations
    Jul 30, 2009
    296
    Code:
    22:45:09.843  Conference server is connected:    application:mediaserver:0/3CXConferenceRoom    local:127.0.0.1:5482    remote:127.0.0.1:52467
    22:45:07.238  IVR server is connected:    application:mediaserver:0/IVRServer    local:127.0.0.1:5482    remote:127.0.0.1:52465
    22:45:02.325  Parking Orbit server is connected:    application:mediaserver:0/3CXParkOrbit    local:127.0.0.1:5482    remote:127.0.0.1:52462
    [b]22:45:01.933  Connection with IVR server is lost
    22:44:59.870  Endpoint 000000F6@ is not found!
    22:44:58.264  Media server is connected:    application:mediaserver:0/MediaServer    local:127.0.0.1:5482    remote:127.0.0.1:52453
    22:44:58.263  [CM112000] Media Server is connected
    22:44:47.221  Connection with Parking Orbit server is lost
    22:44:38.044  Connection with media server is lost[/b]
    22:44:36.773  [CM504002]: Ext.Boomerang: a contact is unregistered. Contact(s): []
    22:44:36.773  [CM504002]: Ext.EndCall: a contact is unregistered. Contact(s): []
    22:44:36.773  [CM504002]: Ext.8102: a contact is unregistered. Contact(s): []
    22:44:36.771  [CM504002]: Ext.8101: a contact is unregistered. Contact(s): []
    22:44:36.769  [CM504002]: Ext.8100: a contact is unregistered. Contact(s): []
    22:44:36.763  [CM504002]: Ext.9999: a contact is unregistered. Contact(s): []
    You need to investigate why your services are crashing.
  16. bduke08021
    Jun 20, 2009
    34
    ok lets try this, what are the possible reasons that i am not getting email notifications?
    I have verified:
    1) the email server is working, when i set up a new ext, they recieve an email, and
    2) the settings for the ext are correct.
    everything else works flawlessly. I just want to get this to work.
  17. tpinnovations
    Jul 30, 2009
    296
    According to the log you posted your services are crashing, this can be for a number of reasons including programmatic error or lack of memory.
    One thing you may wish to investigate is if your ISP blocks large attachments, I have seen some providers block attachments as small as 3Mb.
    Try to set it up with another POP/SMTP server, If you don't have one there are some free options in the VMware department.
  18. bduke08021
    Jun 20, 2009
    34
    i have given up on the clip going out, i have just an email notification and it works fine, they can dial in for now. thanks for your help.
