Voicemail - Auto Logon
Discussion in '3CX Phone System - General' started by dsnyc, Sep 12, 2010.
  1. dsnyc
    Aug 30, 2010
    34
    Is there a way to have voicemail auto logon?
    For example if I call voicemail from ext 100, the system should be smart enough to know that I am calling from x100 and want to check x100 voicemail. I should not have to manually enter my extension number.
    Can this be done?
    10,732
    277
    Yes, there is an option in the Advanced/Custom Parameters/VMPINREQUIRED, set this to "0" and you won't be asked for the PIN on any extension.
