Voicemail Beep Volume
Discussion in '3CX Phone System - General' started by Nick7300, Feb 22, 2017.
Tags:
  1. Nick7300
    Feb 22, 2017
    Where can I change the volume of the beep used at the end of voicemail announcements?
    I have reduced the volume of beep.wav in ivr/prompts/sets
    as well as the beep.mp3 in ivr/prompts.
    Changing both to a lower volume has not solved the problem.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @Nick7300
    The correct path for the prompt set is C:\ProgramData\3CX\Instance1\Data\Ivr\Prompts\Sets and the correct file is the beep.wav. Make sure you are making the changes to the correct prompt set and ensure that the .wav file is at the correct format after you have made the changes.
    also after you make the changes make sure to restart the IVR and media service.
  3. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    106
    38
    Here's a beep.wav that's half length, half volume. The wav file is shared with the beep to leave a message on voicemail, so you can't just delete it.
