Voicemail cutting out after 1 second
Discussion in 'Windows' started by iperez_genius, Jul 17, 2008.
  1. iperez_genius
    Jul 1, 2008
    56
    I am making an incoming call over a voip gateway from a pstn line...
    the call for the pstn line is routed to an extension which obviuosly eventually goes to voicemail.
    After 1 second the line goes silent...it looks like the call is terminating on its own in the server status.
    has anyone ever encountered this problem before?
    Does nayone know how to fix it?
    Ilan
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    Is there the calling party, talking ?
    If not it might be silence detection, what is in your log prior the termination?
    H.
  3. iperez_genius
    Jul 1, 2008
    56
    i am the calling party ...lol and i am trying to leave a message.
    Its definately not because of lack of talking or silence...
    i dont get a chance to talk actually the line goes silent after literally a second
    Ilan
  4. Anonymous
    Anonymous Guest
    Does the call go silent whilst you are still being instructed to leave a voicemail, or after the beep?
    Thanks,
  5. iperez_genius
    Jul 1, 2008
    56
    while the sound file is being played...
  6. Anonymous
    Anonymous Guest
    We would need to see wireshark captures to further debug this one.
    To get technical support, you can contact our technical support (This requires commercial edition with support package). If you have a commercial edition, but no support package, you can purchase one here:
    https://erp.3cx.com/orderform/support.aspx
