Solved Voicemail dialing zero
Discussion in '3CX Phone System - General' started by Milton Schreiber, Dec 12, 2017.
  1. Milton Schreiber
    Dec 31, 2016
    18
    If a caller dials zero while listening to someone's voicemail greeting, where are the settings in 3cx to route the caller? We are on version 15.5 sp2.
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    Hi Milton Schreiber,
    My estimation is that this is un-changable default behavior, it is diverting you to the Operator extension. I have checked the Extension, Voicemail and Parameters settings in 3CX but cannot see anything that can control this.
    Check under PBX Settings you will see: "Callers who transfer out of Voicemail or other menus will be forwarded here"
    You can set who will be the Operator extension so this gives you some flexibility.
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    You can create also a dummy extension as operator extension and forward it to queue, ring group, etc.
    NickD_3CX and eddv123 like this.
  4. Milton Schreiber
    Dec 31, 2016
    18
    Thank you both. That's exactly what I needed.
