voicemail: disable leaving a message
Discussion in '3CX Phone System - General' started by rene_dyn, Dec 23, 2011.
  1. rene_dyn
    Dec 23, 2011
    How can I disable leaving a message for the voicemail? So basically I just want the voicemail to play a message when people call. Thanks!
    10,868
    304
    I'm not aware of any way to disable the recording of incoming messages.
    What you could do is word your message in such a way that they get the idea that they can't leave a message, (this is ABC computers, we are closed today, blah, blah, blah...thank you, and goodbye) then either leave a l o n g pause (dead air) at the end, so they will hang up, or, record a busy signal for a minute or so. That will let them know that they are to not to even try to leave a message.
  3. snowsam
    May 26, 2011
    79
    Don't use voicemail. Use an auto attendant (digital receptionist) instead.
  4. alwicom
    Mar 11, 2010
    Hi, but auto attendant is not accessible for the final user only for admin. Instead a single user can personalize their greeting message and activate forward... but it cannot disable leaving a message.
