Voicemail does not pick up
Discussion in '3CX Phone System - General' started by Anonymous, Nov 10, 2006.
  1. Anonymous
    Anonymous Guest
    I have Beta3 installed and 2 ext configured.
    I make a call to the other ext and voicemail never picks up.
    Also, what do you have to dial to check voicemail? Am I missing a whole chunk of the manual that covers voicemail?
  2. Anonymous
    Anonymous Guest
    It seems that the softphone I was using was creating the problem. I ave switched to a different one and voicemail does pick up now.
    In phone ext that are not registered, VM does not pick up. I just get a 404 not found. The only way I can leave a voicemail for an ext is if it's registered? What if that person is not in the office and they have a laptop with a softphone?
    Still can't figure out what to dial to get into my voicemail box.
  3. Alexander
    Nov 10, 2006
    How to listen to voice messages
    You can hear your voice messages (which were left for you) by dialing the special menu number (can be defined within the 'General settings'). By default this is 999.
  4. Anonymous
    Anonymous Guest
    Which software were you using when your voicemail failed. I am using xten light and I also have eyebeam which i am trying here in a second?
