Voicemail doesnt work with new 3cx upgrade
Discussion in '3CX Phone System - General' started by iainaa, Feb 21, 2008.
  1. iainaa
    Oct 23, 2007
    21
    Hi All,
    Got one big problem , when i log into voicemail 299 it asks me to enter extension number then it pauses and says thank you and goodbye. This has only happend since i upgraded to the latest version. Has anyone got any ideas how to fix this ?
    Thanks In Advance.
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Thanks for your post.
    If you enter extension number are you hearing 'Please enter PIN then press pound' ?
    What phone are you using?
