Voicemail E-Mail to Exchange Distro Group
Discussion in '3CX Phone System - General' started by ablesoft, Mar 29, 2010.
  1. ablesoft
    Mar 29, 2010
    I've setup an Exchange 2007 Mail-enabled distro group to capture a certain extension's voice mail emails. I can confirm in the voicemail xml file in the file system that the email is failing, I also looked the VoiceBox log and am getting this error:
    Mailbox unavailable. The server response was: 5.1.1 <Voicemail@ourdomain.com> is not a valid mailbox
    I confirmed this group exists by sending an email to it through Outlook, so the mailbox exists. I did read on another thread that I needed to uncheck the 'Require that all senders are authenticated' in Exchange and I did that but the email still wasn't getting through.
    I did find a way around it by putting the email on a different server but I would like to have it use our Exchange groups.
    I'm running 3CX Version 8.0.10116 which is the latest. And Exchange 2007 is on a Windows Server Standard machine.
    Any suggestions? Thanks in advanced.
