Voicemail greeting management from phone
Discussion in '3CX Phone System - General' started by giwm, Jan 5, 2018.
  1. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    When a user goes on vacation, they want to record a vacation greeting that can easily be switched back to the default when they return. However, I cannot figure out how this can be done. What am I missing? I'm struggling to believe that this isn't possible from the phone.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
  3. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    Thank you for your feedback. We know how to set a greeting. The question is how to set what some systems call an alternative greeting or a vacation greeting. 3CX only has a single greeting accessible from the phone, so when you come back from a vacation users have to re-record their standard greeting. My users want to be able to switch back rather than re-record.
  4. JWillScott
    Nov 18, 2017
    12
    Extensions > Edit > Forwarding Rules
    Scroll down to greetings, and there is a spot to:
    When in this status, use this custom Voicemail greeting
    I've never tried it, but it looks like what you are hunting for. You might have to help the users record the greeting for that status, but afterwords, they should just be able to use a dial code to change the status of their extension.
  5. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    This may be the closest we can come... but it still means an administrator has to get involved.
  6. JWillScott
    Nov 18, 2017
    12
    NOPE! Good news!
    If the user logs into their webclient
    XXX.XXX.XXX.XXX:5001/WEBCLIENT
    Click on Settings > Greetings
    They can manage the greeting for all of their statuses and even record new ones! (Just make sure all their Rights are set in their extension.)
  7. Saqqara
    Mar 12, 2014
    1,252
    203
  8. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    sadly still can't delete greetings from any of these...
  9. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    So, back to the original question: Still a "no" on being able to manage these from the phone.
    Though it offers one solution, we don't use the web client for a number of reasons. Maybe once it matures we will, but still: The question is about managing from the phone. Like if you accidently left for vacation and had to call in to do it.
  10. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @giwm
    For the users to be able to do this from the phone or by calling into the system the users will have to have pre-recorded greeting for different status and switch between them from the phone or by calling in to the system. They can do that from the web client, windows client or an android client. So if they out of the office,they can call into their voicemail and switch status which will switch the greeting as well. Once they are back they can switch their status back and the greeting will switch back.
  11. giwm
    giwm New Member
    Sep 27, 2016
    246
    42
    So... as just a phone system: No. Bummer. I'll just hope the post in Ideas gets traction so my people can manage their voicemail greetings from the phone. Seems like that'd be a very basic, popular request, but... oh well.
    Thanks.
