Voicemail Greetings Saved but not Assigned
Discussion in '3CX Phone System - General' started by D Caviness, Aug 8, 2017.
  1. D Caviness
    Apr 18, 2017
    21
    3CX ver: 15.5.5
    Now that we have went live, Extensions are recording their Voicemail Greetings, hitting pound and then '0' to save. When a call triggers their voicemail, they get the default greeting. If I go into the extension, under Voicemail, it shows blank in the greeting box. I then have to click on the box and choose the savedmgreeting.wav file, then 'OK.'
    I'm spending a half of day now going through all extensions manually assigning the greeting...
    Is there something the folks are doing wrong? Is there a setting somewhere? Is it a bug?
    Thanks,
  2. D Caviness
    Apr 18, 2017
    21
    No one else has had this problem?
  3. leejor
    11,105
    329
    Is there not an option, per user, to choose which message (personal, or default) to be used?
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
    Hello @D Caviness
    Please upgrade to V15.5 SP1 which is version 15.5.3849.1 that includes a fix for the issue you are facing. Let us know if that works for you.
