- Joined
- Apr 8, 2013
- Messages
- 3
- Reaction score
- 0
has anyone encountered where the Voicemail for certain extension hangs up? The issue is when you dial the extension it rings, the voicemail greeting happens, then there is a beep and call gets terminated and does not allow to leave VM. Currently it's happening on two extension. Phones are registered, and even if the phone is offline and goes to VM directly because the phone is offline it does the same. Can ideas as to why? The extension with the issue is x4973
Please see log report
04/08/2017 11:44:47 AM - Terminated from "Ludmila L."<sip:10007@removed_IP:5060>;tag=c12cfb28 to <sip:[email protected]:5060>;tag=f77b7760; reason: LocalBye
04/08/2017 11:44:47 AM - L:5398.1[Line:10007<<+7600] Sending: OnSendReq Send Req BYE from 0.0.0.0:0 tid=1d1ea965e226d502 Call-ID=-4cto0IKOkobJ9fRAtL9Wg..:
BYE sip:10007@removed_ip:5060 SIP/2.0
Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---1d1ea965e226d502;rport
Max-Forwards: 70
Contact: <sip:4973@removedip:5060>
To: "Ludmila L."<sip:10007@removed_IP:5060>;tag=c12cfb28
Call-ID: -4cto0IKOkobJ9fRAtL9Wg..
CSeq: 2 BYE
Content-Length: 0
04/08/2017 11:44:47 AM - SendMsg from <sip:4973@removed_ip:5060>;tag=f77b7760 to "Ludmila L."<sip:10007@removed_ip:5060>;tag=c12cfb28
04/08/2017 11:44:47 AM - L:5398.3[VMail:4999] got Terminated Recv Req BYE from 127.0.0.1:5483 tid=300db7094903674d Call-ID=nsX5PlHDheWqQFlsGi6U5w..:
BYE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:5483;branch=z9hG4bK-524287-1---300db7094903674d;rport=5483
Max-Forwards: 70
Contact: <sip:[email protected]:5483;rinstance=4ac817c08fdde345>
To: "Ludmila L."<sip:[email protected]:5060;nf=b>;tag=9726346f
Call-ID: nsX5PlHDheWqQFlsGi6U5w..
CSeq: 2 BYE
User-Agent: 3CX Voice Mail Menu
Reason: SIP;text=User Hung Up
Content-Length: 0
Max-Forwards: 70
CSeq: 2 BYE
Content-Length: 0
Max-Forwards: 70
CSeq: 2 BYE
Content-Length: 0
