Voicemail hangs up on me :(
Discussion in '3CX Phone System - General' started by JPElectron, Apr 10, 2009.
  1. JPElectron
    Apr 10, 2009
    12
    Fresh install of the latest version on Windows 2003 Web Edition - very slick, easy!
    Calling between my two extensions works great, calling the Digital Receptionist or Voicemail extensions results in nothing but being hung up on - don't get any instructions/announcement/login, can't press 9, just get "call ended" then fast busy signal untill I hang up.
    Tried changing Voicemail extension, no luck. Perhaps this is related to 127.0.0.1 IP seen in the log? but I could not find a way to set that to be the server's real IP. Server IP is static at 192.168.21.222
    From the log...
    15:51:03.265 [CM503008]: Call(1): Call is terminated
    15:51:03.250 [CM503008]: Call(1): Call is terminated
    15:51:00.437 [CM503007]: Call(1): Device joined: sip:999@127.0.0.1:40600;rinstance=4092171b238ef2e5
    15:51:00.421 [CM503007]: Call(1): Device joined: sip:101@192.168.21.100:5060
    15:51:00.421 [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] Transport: [sip:127.0.0.1:5060]
    15:51:00.406 [CM503002]: Call(1): Alerting sip:999@127.0.0.1:40600;rinstance=4092171b238ef2e5
    15:50:59.859 [CM503004]: Call(1): Calling: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=4092171b238ef2e5]
    15:50:59.812 [CM503010]: Making route(s) to "Voice Mail"<sip:999@sip.test.jpelectron.com>
    15:50:59.781 [CM505001]: Ext.101: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] Transport: [sip:192.168.21.222:5060]
    15:50:59.765 [CM503001]: Call(1): Incoming call from Ext.101 to "Voice Mail"<sip:999@sip.test.jpelectron.com>
    15:50:36.765 [CM504001]: Ext.101: new contact is registered. Contact(s): [sip:101@192.168.21.100:5060/101]
    15:50:17.843 [CM504008]: Fax Service: registered as sip:888@192.168.21.223:5060 with contact sip:888@192.168.21.223:5100;user=phone
    15:49:07.875 [CM504001]: Ext.101: new contact is registered. Contact(s): [sip:101@192.168.21.100:5060/101]
    15:46:54.812 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.21.107:5060/100]
    15:45:35.453 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:800@127.0.0.1:40600;rinstance=436fb0939442ed1a/800]
    15:45:35.453 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600;rinstance=4092171b238ef2e5/999]
    15:45:22.843 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=576096a3e00baf6b/*1]
    15:45:22.828 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=65ee9259e3eac59c/*0]
    15:45:19.125 [CM112000] Media Server is connected
    15:45:17.765 [CM504008]: Fax Service: registered as sip:888@192.168.21.223:5060 with contact sip:888@192.168.21.223:5100;user=phone
    15:45:16.640 [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    15:45:16.640 [CM306001]: Address of STUN server (stun2.3cx.com) could not be resolved!
    15:45:02.062 [CM306001]: Address of STUN server (stun.3cx.com) could not be resolved!
    15:44:52.656 IP(s) added:[192.168.21.222,192.168.21.223]
    15:44:42.812 [CM501006]: Default Local IP address: [192.168.21.222]
    15:44:42.593 [CM501002]: Version: 7.1.6292.0
    15:44:42.593 [CM501001]: Start 3CX PhoneSystem Call Manager
    15:44:42.593 [CM501007]: *** Started Calls Controller thread ***
    15:44:42.484 Unknown system [DBProvider] tries to connect!
    15:44:42.281 [CM501010]: License Info: Load Failed
    Thanks in advance for your help, willing to try anything to prove this works before purchase!
  2. JPElectron
    Apr 10, 2009
    12
    ok, so apparently...
    My DNS config was not up to par - not only do you need an A record pointing the FQDN to the server running 3CX, but you need the SRV record as described in: http://www.3cx.com/support/sip-dns-configuration.html (note upd is the one that's needed, not tcp as pictured in the GUI)
    After that was fixed I would get a recorded error message when calling VM or DR, and learned that IVR runs from the site in IIS, and it did not like that I decided to run in on port 80 - under advanced I told it to run on 5484 too.
    Now everything is cool - just thought I'd leave this here incase anyone else runs across this same issue.
