Voicemail Issue
Discussion in '3CX Phone System - General' started by Ecommerce, Apr 7, 2008.
  1. Ecommerce
    Apr 7, 2008
    8
    I finally got around to playing with our install of 3cx this morning because I can not seem to go to sleep. Everything except voicemail is working. When the server transfers someone to voicemail, the line just goes silent and nothing happens... When I dial 999 (to check voicemail) it reports no new messages and to press 9 for advanced options. if I press 9, the line goes blank.
    It does not place any info in the logs...
    Any ideas on how to resolve this?
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Is this internal, external or both type of calls? Does the automated attendant work? Check your firewall and maybe reinstall. Without log info it's hard to tell.
    What OS is it?
  3. Ecommerce
    Apr 7, 2008
    8
    Automated attendant works fine, no problems. Every thing else works, but when the system forwards to Voicemail it goes silent, and just holds the line open until you hang up. Happens with any type of call, and there is no Firewall setup at this time, so all traffic can flow freely. It is a Windows 2003 box, nothing else running.
    Log below...
    21:36:50.729 Call::Terminate [CM503008]: Call(43): Call is terminated
    21:36:50.698 Call::Terminate [CM503008]: Call(43): Call is terminated
    21:36:50.260 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10001 forwards to VM:4346
    21:36:40.057 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10001 forwards to VM:4346
    21:36:40.041 CallCtrl::eek:nLegConnected [CM503007]: Call(43): Device joined: sip:xxx.xxx.xxx.xxx:5061
    21:36:39.885 CallCtrl::eek:nLegConnected [CM503007]: Call(43): Device joined: sip:
    21:36:39.870 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(43): Calling: IVR:RecordMessage@[Dev]
    21:36:39.854 Line::printEndpointInfo [CM505003]: Provider:[nexvortex1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sippy] Transport: [sip:xxx.xxx.xxx.xxx:5060]
    21:36:39.854 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10001 forwards to VM:4346
    21:36:39.823 CallCtrl::eek:nIncomingCall [CM503001]: Call(43): Incoming call from 2053704347@(Ln.10001@nexvortex1) to [sip:4346@xxxx.com:5060;user=vmail]
    21:36:39.745 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10001 forwards to VM:4346
