VOICEMAIL LENGTH
Discussion in '3CX Phone System - General' started by adminjay, Dec 3, 2007.
  1. adminjay
    Dec 3, 2007
    I am having issues with voicemail length, it seems each voicemail can only have a maximum length of 62 seconds, is this true?, or is something wrong in my system, I tried it internally extension to extension many times after a few clients told me it only recorded part of their message then said press 0 to save, etc. etc., thanks in advance for your support, jay
