Voicemail Login
Discussion in '3CX Phone System - General' started by nupton, Apr 11, 2008.
  1. nupton
    Oct 5, 2007
    27
    Hello. Is there a way to bypass entering the extension number and personal identification number when accessing voicemail? In other words the system would recognize the extension number and PIN from the specific phone calling voicemail. I'm using a Cisco 7960 and I'm able to configure the Message button to dial 999 when pressed, and was wondering if I can automate the login process as well. It's probably more configuration on the Cisco side but was wondering what options, if any, are available on the 3CX side.
    Thanks!
    -Scott
  2. Arnaud
    Nov 23, 2007
    43
    Hi Scott, I don't believe you can dial a string from the message button. Just a plain simple extension only.
    I tried some constructions with # and commas etc. in the string, separating the 999 from the extension and pinnr, but wasn't succesful.
    Other PBX solutions solve this at the server side. The sever, when being called (at extension 999 for example) just looks where the call came from, and adds when configured that way the appropriate extension and pinnumber.
    Doing it that way would make it more generic, and phone manufacturer independant. A feature request ?
    Arnaud
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    Not sure if it can be done, but have you tried adding pauses (p) to the dial string? this might have the right about of delay to allow the phone to 'auto input' the code. Just a suggestion.
  4. Arnaud
    Nov 23, 2007
    43
    Tried this, didn't work. Look like 3CX doesn't like anything but numbers.
