Voicemail menu access
Discussion in '3CX Phone System - General' started by MB1, Feb 11, 2011.
  1. MB1
    MB1
    Nov 2, 2007
    39
    I am trying to allow an external caller to access the voicemail menu. So, when the voicemail picks up, they dial 99 and then enter a pin number, then press 9 and access is granted to the menu options.
    My setup is as follows: POTS to MP114 to 3CX V9.
    However it only works as fiollows:
    1) If the call is internal (ie internal phone connected to my MP114), 99 can be dialed from the dialtone and menu access is possible.
    2) If the caller is external then I wait for voice mail to activate, but when I dial 99 I briefly get the on hold music then it goes back to voice mail again.
    Any ideas?
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    I posted this in another thread yesterday (I thought it was your thread)
    To get to the voicemail menu from externally (thats an external number not a remote 3cx extension) you can only go through a Digital Assistant.
    We often set up a digital assistant for that and get them to press 1 and it sends to voicemail. But in any digital assistant you can press the voicemail number (99 in your case) and it will work.
