voicemail menu press * how to disabled.
Discussion in '3CX Phone System - General' started by Tom De Brouwer JFS, Mar 29, 2018.
  1. Tom De Brouwer JFS
    Mar 27, 2018
    12
    All,
    When someone gets to the voicemail menu, they get the choice to leave a message or press ‘*’ to get in touch with a
    Co-worker.
    This last option should be disabled, but I cannot find out how to do it.
    In the settings pbx there is an option “enable outgoing calls in voicemail menu” which I have disabled.
    Still it remains possible to make a call through the voicemail.
    Is this a bug, or am I missing something?
    Thanks in advance!
    Kind regards,
    Tom De Brouwer
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    The star code is built in - to go to the operator.
    Many have mentioned this - but no change has occurred. Some have changed the default message in the promptset that doesn't tell them about the "*" key. And, if I recall, 0 does the same thing.
    Tom De Brouwer JFS likes this.
