Voicemail - No Audio - on old version V7
Discussion in '3CX Phone System - General' started by SnAzBaZ, Jan 13, 2009.
  1. SnAzBaZ
    Nov 9, 2007
    28
    Sometimes when we call the voicemail system, you don't hear any audio, the call connects. You can press * etc to play messages, but nothing happens.
    Also, we often get the message "An Error occurred in IVR Session"
    I have not yet been able to identify a pattern as to when this occurs, the no audio is fixed by restarting all 3CX services, which is something I would like to not have to do!
    We are running 3CX V7.0.3775.0
    The log files do not show anything different when we get no audio.
    Andrew
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Re: Voicemail - No Audio - 3CX V7
    HI
    The build you are running is a pre-release build of V7 . We recommend that you upgrade to the latest build to see if you still encounter the issue.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Also we released a newer version today - please update your server. version 4744
