Voicemail not working
Discussion in '3CX Phone System - General' started by cmdowning, Aug 24, 2008.
  1. cmdowning
    Aug 24, 2008
    I've just installed the 3CX software, have several extensions setup, and voicemail doesn't work on any of them. It's enabled, and the service is started, but when something is transferred to voicemail, it's just silent. It doesn't disconnect the call, but just sits there doing nothing. Everything else with the system seems to be working ok. Any advice? Thanks.
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Do you have this problem on incoming calls or also on calls between internal extensions too?
    If it is happening on incoming calls, does it happen with a PSTN gateway or a VOIP provider?
    If you dial 999 do you hear any message or you also hear silence?
  3. cmdowning
    Aug 24, 2008
    If you dial 999 (although has been changed to 900 at this point), you do hear something. Although when you hit 9 for more options, you don't hear anything at that point, and changing your message doesn't work.
    It happens from internal and external calls.
  4. alexmallia
    3CX Support
    Aug 4, 2008
    130
    To get technical support on this one, you can contact our technical support (This requires commercial edition with support package). If you have a
    commercial edition, but no support package, you can purchase one here:
    https://erp.3cx.com/orderform/support.aspx
    regards
  5. SWB
    SWB New Member
    Mar 26, 2008
    136
    Does this happen on all phones, including the client?
  6. cmdowning
    Aug 24, 2008
    It does happen on all phones, and happens when an external call is transferred to voicemail.
  7. SWB
    SWB New Member
    Mar 26, 2008
    136
    Ok how are you transferring the calls to voice mail? Does the log indicate the correct route?
    I ran into a problem with silence when connecting to the conference call prompts. I was connected to the conference call extension, but nothing was played. What I did to rectify it was create a new prompt set and then browse to each of the conference prompts and select them. For whatever reason that worked for me. Don't know as to why it couldn't play the default prompts, especially when I selected the same prompts in my custom prompt set.
