Voicemail Notification Rollover
Discussion in '3CX Phone System - General' started by Chrispy009, Jul 2, 2013.
  1. Chrispy009
    Jun 26, 2013
    We're trying to replicate a feature in our current phone system. We looking for a voicemail notification to go out to a tech for after hours support. If that tech does not answer or listen to the voicemail in a certain amount of time or number of calls, we'd like it to rollover to the backup tech and call them. Does anybody know of a possible way to do this? Thanks!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,552
    298
