Voicemail notification
Discussion in '3CX Phone System - General' started by David_nz, Oct 2, 2008.
  1. David_nz
    Sep 27, 2008
    Hi All,
    I am using SPA922 phones with the 3CX phone system - so far all is working well (sip providor issues not withstanding!) but I have noticed that the message waiting light on the phones does not come on when there is a new message waiting - is there something I need to do to enable this? If I turn it on, the email notifaction works well, but for some of my users the light would be a better bet.
    Thanks in advance.
    Dave
  2. KrisHansen
    Apr 30, 2008
    22
    Hi David,
    First off with VOIP providers, if youre in NZ try out 2talk.co.nz , Ive tested them out & we have a template to use for setting them up on wiki.3cx.com under VOIP Providers.
    With the SPA922, I dont believe Linksys BLF works well with 3CX which may also relate to Voicemail notification as this is similar. When setting up Voicemail on any phone ensure it uses the Voicemail number 999, Asterisk use *97 & I find this is the default on a lot of phones that need to be changed to 999 for 3CX.
