Voicemail on free version
Discussion in '3CX Phone System - General' started by h2009, Mar 17, 2008.
  1. h2009
    h2009 Member
    Mar 15, 2008
    447
    Is there anyway to alert a user (other than by email) if they have voicemail, i.e. like a call reminder?
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    Ack another problem - Calling from outside the network i can hear people, they can hear me. But when i call my voicemail number i cant hear the audio. here is the log;
    17:27:40.234 Call::Terminate [CM503008]: Call(3): Call is terminated
    17:27:36.187 MediaServerReporting::RTPSender [MS004000] C:3.1: (ACTIVE): Can't send RTP stream to 1 destination unreachable
    17:27:36.187 CallCtrl::eek:nLegConnected [CM503007]: Call(3): Device joined: sip:115@192.168.0.196:5060
    17:27:35.609 CallCtrl::eek:nLegConnected [CM503007]: Call(3): Device joined: sip:
    17:27:35.593 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(3): Calling: IVR:900@[Dev]
    17:27:35.593 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:900@192.168.0.200]
    17:27:35.593 Extension::printEndpointInfo [CM505001]: Ext.115: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NCH Swift Sound Express Talk 3.04] Transport: [sip:192.168.0.200:5060]
    17:27:35.578 CallCtrl::eek:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.115 to [sip:900@192.168.0.200]
  3. Halea
    Halea New Member
    Jan 5, 2008
    151
    You can always write a small program that would go and screen through the database and turn on the phone indicator accordingly. You could even make money by selling it as an after-market add-on :|
    :roll: Halea
  4. techknows
    Mar 15, 2008
    7
    I think the purchase is well worth it. Especially for the BLF.. But then again I have Grandstream Phones..... They dont get along with BLF code very well ....
  5. radelman
    Feb 21, 2008
    60
    I also have Grandstream phones, 2010's and they did not get along well with the BLF either, UNTIL, I downloaded the latest firmware upgrade directly from this Grandstream server: 72.72.74.219/GXP20X0. I obtained easily the fix through HTTP in a about 3 miute download.
    Richard
