Voicemail / operator
Discussion in '3CX Phone System - General' started by ikonectu, Nov 25, 2014.
  1. ikonectu
    Mar 26, 2013
    16
    I recently recognized an issue (thanks to a potential client) that when a caller, internal or external, reaches voicemail if they dial * or 0 to reach the operator they are getting my mailbox and can listen to old messages, change greetings, anything that I can do, they can also. I have a password set on all voicemails and it is enabled.
    Any ideas what is going on?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    Do you have an operator set under Settings -> General ?
    You say you have a password set and enabled - do you mean under Extension -> Voicemail -> "Disable Voicemail Pin Authentication" is unchecked...
    I have never seen this happen before on my system?
