voicemail pin then system hangs up
Discussion in '3CX Phone System - General' started by cloud9mike, Jul 22, 2008.
  1. cloud9mike
    Jul 22, 2008
    5
    New user here so thanks in advance to everyone....
    I have 3CX setup and working with Linksys gateway... I am trying to get the voicemail configured. I connected to the server with the 3cx softphone and everything is working fine.....
    dial 999
    asks me for my pin press #
    Then it responds thank you and hangs up. I was hoping that I could record an mp3 and tell it to play that as my vm greeting but I can't seem to get that done. Just looking for some help to get my vm greeting setup and get down the road.
    Thanks,
    Mike
  2. cloud9mike
    Jul 22, 2008
    5
    That didn't work... That is exactly what I was trying to do.. Thanks for the reply, any other ideas???
    Also, when using the softphone I don't get any tones when pushing the buttons... So I don't know if/when it takes the # that I click on...
  3. cloud9mike
    Jul 22, 2008
    5
    I will try a new extension tonight.
  4. cloud9mike
    Jul 22, 2008
    5
    I have 2 way audio... I don't have a digital receptionist set up as of yet.... Thanks for all the input.. I will look at a few things tonight and post after that... Great board!
    Mike
